MSUdom5
by MSUdom5 » Sat Nov 08, 2008 6:03 am
Indigo doesn't parse the following:
def blend(vec3 tex1, vec3 tex2, real blendamt) vec3: (tex1*blendamt)+(tex2*(1.0-blendamt))
def eval(vec3 pos) vec3 : blend(sample2DTextureVec3(0,getTexCoords(0)),
sample2DTextureVec3(1,getTexCoords(0)),
doti(sample2DTextureVec3(2, getTexCoords(0))))
Gives the message:
Fatal Error: IndigoDriverExcep: SceneLoaderExcep: Lexer: Failed to parse int Line 1, column 41 (In element 'shader', around line 66, column 13)
Onfame
by Onfame » Sat Nov 08, 2008 7:18 am
This how it works:
def blend(vec3 tex1, vec3 tex2, real blendamt) vec3 : (tex1 * blendamt) + (tex2 * (1.0 - blendamt))
- thatstheresult.jpg (78.32 KiB) Viewed 2069 times
MSUdom5
by MSUdom5 » Sat Nov 08, 2008 8:06 am
Ah, so you have to have spaces in certain places? Hmm.. tisk tisk...
by CTZn » Sat Nov 08, 2008 8:10 am
You mean blank spaces matters, Onfame ?
Onfame
by Onfame » Sat Nov 08, 2008 8:20 am
YES allways the blank spaces are the bad
AND i changed this:
to this
Ok i tested again the last is not necessary, but if you use +-*/ allways use Blanks.
by CTZn » Sat Nov 08, 2008 8:36 am
AND i changed this:
to this
Do you want to drive me crazy
? Ah no I see it now
Many thanks for the hint, and nice "rojulero" mat !
Onfame
by Onfame » Sat Nov 08, 2008 8:42 am
Sorry my english isn´t that good, what exactly does "rojulero" mean
