by PureSpider » Mon Jun 09, 2008 7:39 am
I've noticed that, if a meshlight is partially in a transparent, the part not in the material goes black, this happens in all versions of indigo i tried it... 1.0.9_2, 1.1.1 and 1.1.2
See the attached shot for details
- im1212949738.png (309.49 KiB) Viewed 3303 times
by Kram1032 » Mon Jun 09, 2008 8:15 am
Is the transparent closed? (Not that it should affect the part outside
I guess, you checked the normals myriades of times?
Really strange bug...
by PureSpider » Mon Jun 09, 2008 8:40 am
Yes it is closed and yes, I did check the normals
Olis
by Olis » Mon Jun 09, 2008 9:35 am
I made this simple experiment in order to recreate the bug. Through the right sphere there is a meshlight cylinder and inside the left sphere there is a sphere meshlight for reference.
- Indigo v1.1.2 X64 on Vista X64
- im1212959205.png (326.05 KiB) Viewed 3241 times
Your lights stand no chance against the Indigo sun!
by PureSpider » Mon Jun 09, 2008 9:38 am
It's not always like that... normally meshlights partly in transparent mats work just fine, but not in that very special case (a ring in a ring, like it seems to be)... however I'll do that test, too
Olis
by Olis » Mon Jun 09, 2008 9:56 am
I made a scene similar to yours and it works perfectly.
- im1212961147.png (348.02 KiB) Viewed 3224 times
by PureSpider » Mon Jun 09, 2008 10:05 am
Okay I dunno what's this all about, but I made another test and it's still f00ked up...
You can find the scene file here: €dited
€dit: What prog are you using? Maybe this is related to the Cindigo export instead of indigo itself?
- Note the small cylinder having the very same mat as the outer torus
- im1212961644.png (490.53 KiB) Viewed 3218 times
PureSpider on Thu Jan 07, 2010 11:00 am, edited 2 times in total.
Olis
by Olis » Mon Jun 09, 2008 10:07 am
What 3D package do you use? Blender?
by PureSpider » Mon Jun 09, 2008 10:08 am
Edited my previous post just the moment you posted... I'm using C4D
Olis
by Olis » Mon Jun 09, 2008 10:10 am
Look at my sign
Maybe you could export your scene to a .obj file or something so that I can look at it?
by PureSpider » Mon Jun 09, 2008 10:10 am
Look @ the link in my post above... There is the pigs file, just open that with Winzip/Winrar/similar to get the .obj's
Olis
by Olis » Mon Jun 09, 2008 10:25 am
I looked at the file and I didn't see anything other than that your outer torus is strangely closed.
- Mine on the left, your on the right.
- torus2.PNG (121.46 KiB) Viewed 3194 times
by PureSpider » Mon Jun 09, 2008 10:30 am
That's the way C4D is doing it =/
Olis
by Olis » Mon Jun 09, 2008 11:00 am
But surely there must be a way to do it manually?
by OnoSendai » Mon Jun 09, 2008 3:06 pm
Don't partially intersect mesh lights with media, it's not allowed in Indigo
