Light Intensity
Light Intensity
before i start doing tests, does anyone have any examples of how light intensity is distributed over a mesh?
i know when you enable Efficacy Scale then bigger meshes will appear darker due to the energy being distributed over the whole mesh. is this so for simple RBG/Gain?
can there be an option of something like "W/m^2" or something so that you can keep the relative light intensity between different emitter sizes?
also, if im using RGB/Gain, does anyone have a good ballpark for adjusting the Gain so that the lights are balanced with daylight/sunset?
thanks!
thanks!
Re: Light Intensity
Add in env map, and you are pointing at the most complicated usability "issue" in our lovely and quite simple to use IndigoStompinTom wrote:does anyone have a good ballpark for adjusting the Gain so that the lights are balanced with daylight/sunset?
I'm planning to add Luminous emittance (http://en.wikipedia.org/wiki/Luminous_emittance)
as an option for emitters in Indigo as well.
This is a measure which means that a larger light will emit a greater radiant flux, and the amount emitted per unit surface area will be independent of the size of the light.
This sounds good master Ono...!
I hope this one goes fine with Reinhard... :/
Is there any "normalisation" betwenn the light "classes" involved too?
Can we finally have a env map lightened scene get working with blackbody & RGB emitter without 1001 test renders to tweak everything?
Users browsing this forum: No registered users and 116 guests
