Page 1 of 1
I can see bumps on alpha mask render ???
Posted: Thu Apr 24, 2008 7:04 pm
by delic
I can see bumps on alpha mask render, is that wanted ?
Or did I set the bumps too high on negative values ?
Posted: Thu Apr 24, 2008 8:35 pm
by Vanessa07
I think your talking of reflects! It's can be both a problem and a good think to keep your render "true"
Posted: Thu Apr 24, 2008 9:21 pm
by delic
It's on the objects where I set a bump map with high neg values ...
Do you mean it could be where the alpha background is refelcted ?
My phong objects should then be half transparent regarding to alpha render ...
Posted: Thu Apr 24, 2008 9:43 pm
by Vanessa07
Yes, did you try with diffuse mat?
Posted: Thu Apr 24, 2008 10:05 pm
by Kram1032
btw, an Image of the problem would be nice ;)
What do you want to get with a negative bump? That inverts the map. Is that, what you want?
Posted: Fri Apr 25, 2008 7:49 am
by delic
for bump maps, I'm not sure about a thing in indigo, is grey = 0, or is white = 0, with positive/negative values as direction.
If you say neg inverts, the bump maps should be grey based, black up or white up ?
From blendigo, are the values according to the world scale exponent ?
Posted: Sat Apr 26, 2008 10:40 am
by Kram1032
The range depends on your settings....
You have the A, B and C value.... ignore A for the moment. Search in the forums for more details - already was asked thousands of times before ;)
Basically, C is your blackpoint and B your Whitepoint. - I think, it's translated to meters which is why the values have to be that low to look right...
If you set a negative B, white suddenly makes holes instead of bumps.
A C-value of exactly 0 would tell Indigo that the lowest colour is black (except, as I said, if your B is negative. Then, black will form bumps instead of holed)
If you want to have 50%-grey in the middle... I think, you would have to set the C-value to the same as the B-value but inverted...
to answer your questions more directly: On default, black=0 and white=1. Grey would be 0.5
To set white=-1, black=1 and grey=0, you should set B to -*yourBumpValue* and C to *yourBumpValue* ;)
Bumpmapping hasn't got anything to do with world scale, I think.... Except the values really are meters.........
Posted: Sat Apr 26, 2008 8:38 pm
by delic
Thx a lot !
:D
Posted: Sun Apr 27, 2008 7:34 pm
by OnoSendai
THis is a known bug, just don't use bump mapping when doing alpha renders.
Posted: Mon Apr 28, 2008 6:47 am
by StompinTom
bah, i guess this is an exporter question, but would it be possible to put in a material override toggle? say if i get the sudden urge to render my whole model with a pink glass material. what i really mean is for clay renderings and such.
by the way, havent thanked you, ono, for the alpha rendering. definitely a TON easier to composite stuff now! i find that the lens matching between Blender and Indigo isnt perfect (somethings off...) so it saves a lot of time scaling and distorting a mask i make in Blender to fit the Indigo rendering!
cool.
