Page 1 of 1
Indigo or Blendigo Bug?
Posted: Fri Aug 24, 2007 3:35 am
by ortega
Well ... im trying make a scene with env. map + emitter, but when a do render with emitter the env. map do dark ... buuuut when i turn emitter off he work ... look the examples and sry about my english
Emiiter ON + Env. MAP
Emitter OFF + Env. MAP
btw...its the second time with same problem
thx
I use, Indigo_v09_test06 + Blendigo 9 s2
Posted: Fri Aug 24, 2007 3:42 am
by Kram1032
that's 'cause you use reinhard tonemapping... (reinhard auto exposures your pic as good as possible, it tries to avoid pure black and pure white pixels)
two ways to get arround that:
1) make your emitter weaker (don't turn it completely off, but make it weaker)
2) use linear tonemapping - a bit harder to use than reinhard, but as long as you export the igi and you can post edit the tonemapping in violet, you shouldn't have troubles with that
Posted: Fri Aug 24, 2007 3:44 am
by Zom-B
its an tonemapping issue!
Black Body is sooooo bright that much more bright could not go!
So use efficiacy_scale for your meshlights, but finding the right values is a try & error work.
You also could try to reduce your Black_body gain value massively!
Posted: Fri Aug 24, 2007 3:54 am
by SmartDen
Just raise Env map gain
Posted: Fri Aug 24, 2007 4:12 am
by zsouthboy
Smartden hit the nail on the head.
Just increase your Env map gain. by 10x or more
Posted: Fri Aug 24, 2007 4:27 am
by SmartDen
zsouthboy wrote:Smartden hit the nail on the head.
5 or 7 should be enough too. Just try out!
Posted: Fri Aug 24, 2007 10:19 am
by ortega
THX guys
Posted: Fri Aug 24, 2007 7:59 pm
by Marcofly
since when can you use env.maps +emitter? did i miss something?
Posted: Fri Aug 24, 2007 9:42 pm
by OnoSendai
Since always
Posted: Fri Aug 24, 2007 10:22 pm
by Marcofly
uh oh..
tnx Nick!
Posted: Fri Aug 24, 2007 11:38 pm
by ortega
how is better? only emitters? thx
Posted: Sat Aug 25, 2007 12:15 am
by SmartDen
ortega wrote:how is better? only emitters? thx
Try both, emitters and EXR. With emitter you can get good shadows and EXR give you nice revlections
Posted: Sat Aug 25, 2007 12:17 am
by deltaepsylon
I guess its better with only emitters. BUT (and its a big but) only if you add some other low power emitters (perhaps 2) around the model, i mean like long rectangular boxes so that you dont get 2 funky shadows. that way, the scene will still be bright, but you will still see the headlamp thing.
-OR-
you could go for a nice smokey.foggy effect and put the whole thing in a giant SSS cube and see the headlamp from the model illuminate a cone of light, that'd be pretty kewl
mind uploading the blend file? id like to take a closer look at that thing, looks interesting
Posted: Sat Aug 25, 2007 2:57 am
by ortega
Blend file uploaded
Need only finish the armature and textures...annnnnnnddd im not very good about modeling
but somenthings work
http://www.inovaplacas.com.br/besteiras/projeto.rar
ftp fron my enterprise
Posted: Sat Aug 25, 2007 2:59 am
by deltaepsylon
kewl, tahnks
