.:: EXIT-PORTALS and 0.9T2
Why when I use dielettric materials I see this circle on exit portal plane ?
- exit-portal.max-frame-0000.png (1.08 MiB) Viewed 2596 times
yes this is .max file (3d studio max with SP2)
and again another little issue...
If the plane (exit-portal) is not aligned with the wall inside
the room I see the circle and a black area out-side the exit-portal
probably I'm wrong something... but I not understand what...
I USE:
- Intel Core Duo 2 -- 1.8 GHz -- 2GB DRAM
- ATI Mobility Radeon X1400
Windows XP Professional with Service Pack 2
3D Studio MAX 9 with SERVICE PACK 2
Indigo Render 0.9 T2
Max to Indigo - 0.9.3c
I USE:
- exit-portal.zip
- (26.72 KiB) Downloaded 140 times
- exit-portal.max-frame-0000.png (1.22 MiB) Viewed 2410 times
probably I solved the problem.
The proble is the MAX object Teapot
this standard version of teapot has in some edge the
normal inverted and this is what you see in exit portal
the exit-portal is like a mirror of wrong normals?
so If i put a shell with 1 unit to teapot and I tranform the
entire object to polygons all is ok...
- The problem of black area out-side the exit portal I not solved...
the current image is a shell teapot...
- exit-portal.max-frame-0000.png (1.25 MiB) Viewed 2395 times
Users browsing this forum: No registered users and 95 guests
