T0.8 Problem
T0.8 Problem
bidirectional + hybrid and hdr
Work some time after, appear mistake, withdraw automatically.
Are you also similar?
- problem.jpg (182.29 KiB) Viewed 3126 times
I've had this happen from time to time. It's a memory bounds problem I believe.
The slightest change to the scene can fix it. I don't know why.
Or, rather, to verify that this is what I'm talking about, go into your .ini file, and set supersamplefactor to 1 (or in the scene XML if you've defined it there)
I bet you won't see the error.
@ Kram1032
English meaning is :indigo.exe meets problem demand to close(probably this meaning, have no special meaning)
@ zsouthboy
Sorry! i can't Clearly understand you of meaning, do you more tell I how to demand modify?
Thx you-all
ini file,
------Output image dimensions------
"width" "600" --Note that the ratio of these should match the camera aspect ratio defined
"height" "450" -- in the scene xml file.
------Metropolis light transport settings------
"metropolis" "false" --if true, use MLT, if false, use pathtracer
"large_mutation_prob" "0.4" --Probability of using fresh random numbers.
"max_change" "0.01" --max mutation size, must be in range [min_change, 1)
"max_num_consec_rejections" "1000"
------General tracing parameters------
"max_depth" "10000" --max ray bounce depth.
"bidirectional" "true" --Use bidirectional path tracing / bidirectional MLT?
"hybrid" "true" --If enabled, direct lighting is computed with path tracing.
-- Indirect lighting is computed with MLT.
------Network rendering settings-----
"frame_upload_period" "30.0" --number of seconds between uploads of image to network master
------Miscellaneous settings-----
"halt_time" "-1" --time in seconds after which to halt the program. Halting is disabled if negative.
"logging" "true" --write to log.txt?
"display_period" "10.0" --number of seconds between display of the render in preview window.
"image_save_period" "20.0" --number of seconds between saves of the render to PNG, EXR and IGI.
"save_tonemapped_exr" "false" --Write .exr tonemapped render as well as normal PNG?
"save_untonemapped_exr" "false" --Write .exr untonemapped render as well as normal PNG?
"save_igi" "false" --Write Render to Indigo Image (.igi)?
"num_threads" "1" --Number of render threads to use. Set to number of cores for fast rendering.
"cache_trees" "true" --Cache kd-trees on disk?
"polarisation" "false" --broken, leave it off.
"super_sample_factor" "3" --a higher value takes more RAM but reduces aliasing along high contrast edges.
"bih_tri_threshold" "500000" --Any meshes with at least this number of triangles will use a Bounding Interval
--Hierarchy (BIH) acceleration structure instead of a kd-tree
@ zsouthboy
Thx you-all
ini file,
Users browsing this forum: No registered users and 90 guests
