Page 1 of 1
Cannot start network rendering
Posted: Sat Aug 19, 2006 9:45 am
by Maluminas
Im following these steps to try and start a network rendering:
http://www.indigorenderer.com/drupal/?q=node/7
but i get an error everytime. It says:
SceneLoaderExcep: failed to load XML doc from path 'ior_test.xml': Failed to open file Line 0, Column 0
I tried several xml files like ior_text.xml and metal_test.xml and scenes exported from Blender which all work just fine when i use the file name in the inifile.txt and use Indigo.exe by double-clic but they all do the same error.
Am i doing something wrong? Im using Indigo 0.5.[/url]
Posted: Sat Aug 19, 2006 9:56 am
by Maluminas
Ok i managed to get it to start...
I was writing: indigo.exe ior_test.xml -n m
But i needed to write: indigo.exe testscenes\ior_test.xml -n m
i found it myself but you should update the page in the link above, its not clear that you must enter the full path from where indigo.exe is. It might be obvious for a pro but not for a newb like me :oops:
Now i have another problem :lol: it starts but i get 0 muts/sec and it says not saving image with zeroed dimensions, or something like that... lol
Posted: Sat Aug 19, 2006 10:11 am
by Kosmokrator
wow very strange msg....and i have some trubles to start the network rendering but now all its ok...btw im max2indigo user... :wink:
Posted: Sun Aug 20, 2006 7:56 am
by Maluminas
I would really appreciate some help :( If i can make it work i can double my muts/sec :twisted:
Posted: Sun Aug 20, 2006 8:01 am
by Wereaser
It appears that you need to run a client on the master computer as well, if you want the master to do add in the rendering. :) I noticed this yesterday when I did my first network rendering tests.
Edit:
Something like this on the command line:
indigo.exe somescene.xml -n s -h yourcomputername_or_IP:7777
[/code]
Posted: Sun Aug 20, 2006 1:50 pm
by Maluminas
It worked! Thanks :D
