Noise Reduction
8 posts • Page 1 of 1
mpro31
Noise Reduction
Post by mpro31 » Wed May 20, 2020 9:48 pm
Hi to everybody,
I'm a new user of indigo so I have a few questions regarding noise reduction. Specifically, why is this happening?
Is it a memory issue? because I've tried different memory values and the bug insists.
Best, K.
Re: Noise Reduction
Post by Oscar J » Wed May 20, 2020 10:43 pm
I have no idea what's going on. Looks like you have some serious problems with your scene. I think you need to attach a description of how your scene is set up and lit.
mpro31
Re: Noise Reduction
Post by mpro31 » Wed May 20, 2020 11:08 pm
Hi Oscar,
thanks for the prompt response,
this issue happens very often. The scene setup made in cinema4D. Lighting uses panels, sometimes using hdr images to simulate a softbox. Maybe is more often in GPU mode but I'll have to run some more tests to evaluate that.
If you need extra info, let me know. I will try different types of lighting, thanks for the hint on lighting.
K.
Re: Noise Reduction
Post by Oscar J » Thu May 21, 2020 3:50 am
I have never come across something like this, so it's probably something you're doing wrong - hence my question. Are you using blackbody values for your lights? The image looks extremely blown out.
mpro31
Re: Noise Reduction
Post by mpro31 » Thu May 21, 2020 5:07 am
Oscar this image is something like a glitch that sometimes appears, sometimes not. The reason it is so bright has nothing to do with very strong lighting. Lights are in RGB, no blackbody.
Re: Noise Reduction
Post by Oscar J » Thu May 21, 2020 5:41 am
You could try uploading a scene for us to check? Maybe reduce that car scene down to its bare essentials.
Zalevskiy
Re: Noise Reduction
Post by Zalevskiy » Thu May 21, 2020 6:55 am
Noticed a similar bug in indigo 4.4.8 release (GPU + Denoise)
Glass/Special/Glass_1SG_Shader_02.pigm
https://yadi.sk/d/R3Gk6i08SL6rQQ
Re: Noise Reduction
Post by Oscar J » Thu May 21, 2020 7:03 am
Interesting, the Intel denoiser was updated with the new release, there may well be a bug in there I guess.
