Washed out colours after exporting
Hi there guys.
I am facing a problem with indigo,i don't know why , but this is happening right after updating to the latest version.
I am getting washed out colours when rendering (right after exporting the file to Indigo ). It can be solved by doing any change in the file ( like changing the rendering modes, materials, sun position etc. Anything that involves re-render the file).
See images below (same settings in both images):
Cheers
Cheers
Re: Washed out colours after exporting
Any Clue ? Please, tell me i am not the only one with this problem
Cheers.
Cheers.
If you send the scene to us we can take a look at it. can you host the PIGS on dropbox or similar and email a link to support@indigorenderer.com, or pm me.
Hi Ono.
Thank you for your reply
I could send you the file, but the issue is with all my projects...sometimes happens sometimes don't.This is been a minor problem since any of 4 versions( till the 4.2.18).
I did not said a word before because of its easy way of solving the problem but, sometimes it gets annoying.
Now i've been working with the 4.2.18 and the problem seem to be gone ( or at least is not showing up so far ).
I'll let you know if the problem persist.
Thank you very much.
Just a whild guess. Do you have your video driver updated?
- zeitmeister
Second wild guess: what color profile do you use in Photoshop(?)?
Is your monitor calibrated?
Color profile of monitor and photoshop should be the same.
Hi zeitmeister.
The problem is when Indigo starts to render after exporting from skindigo( and through the rendering process ).
The saving file process works fine ,if the image is well generated from the begining then the quality of the final image is good
- zeitmeister
... to make it clear to me:
The problem disappeared with 4.2.18 and above?
I know that the sunsky-model has been „corrected“ with OpenCL, so the problem might have been situated there...
It seems everything is fine now. Latest test with Indigo 4.2.21zeitmeister wrote: ↑Sat Sep 01, 2018 8:18 pm... to make it clear to me:
Users browsing this forum: No registered users and 106 guests
