[REQ] v4 video functionality
maybe a timeline in light layer section (with keyframes, rgb and gain slider and everything needed)
[like blender's powerfull timeline]
it's usefull for a light animation with still camera.
now is very tedious! save as, move slider, save as, move slider, save as, move slider......
Re: [REQ] v4 video functionality
There's probably a lot of functionality that could be brought over from Chaotica, including this. Also why does Chaotica still have much more flexible tonemapping options than Indigo?
develoooooooopers.... ??!!??!
Why not saving each LL to a own file and then do your Animation inside a proper Video Editor??
With such a small team like Glare is I would like rather to see them focus on the core features and enhancements instead of bringing stuff that other Software is capable of way better...
#DontWasteDevTime
Seeing the Chaotica tonmapping features would be sweet, since (afaik) it can be ported quite simple because of the same GUI framework
#DontWasteDevTime
tedious is the answer...Zom-B wrote:Why not saving each LL to a own file and then do your Animation inside a proper Video Editor??
#DontWasteDevTime
It's what I do now, but if I had many files in the queue, like a "standard" camera animation, the result is a lot of file/frame... in the case of light layer animation the solution is only a manual move slider / save as /move slider save as .. that saves you!
sorry for my english... explain it is difficult with my english language level! Pibuz help me!
only a proof of concept...
<render_queue>
<item>
<scene_path>XXXXXX</scene_path>
<halt_time>YYYY</halt_time>
<output_path>ZZZZ</output_path>
<layer_variations>
<layer_name>123</layer_name>
<gain_start>1.0</gain_start>
<gain_end>0.0</gain_end>
<step>0.01</step>
</layer_variations>
</item>
</render_queue>
- Originalplan®
I agree with Zom-B. You can import any number of file sequence you rendered in After Effects for example...in the right order.Zom-B wrote:Why not saving each LL to a own file and then do your Animation inside a proper Video Editor??
#DontWasteDevTime
Inside Cindigo you are able to animate and keyframe every element Indigo uses..Lightlayers included.
Im pretty sure with double GPU support rendering videos will be just fine as is.
#DontWasteDevTime
Originalplan® wrote:I agree with Zom-B. You can import any number of file sequence you rendered in After Effects for example...in the right order.Zom-B wrote:Why not saving each LL to a own file and then do your Animation inside a proper Video Editor??
#DontWasteDevTime
#DontWasteDevTime
I'm a poor sketchup user...
ok, #DontWasteDevTime
but....
Onoooooooooooooooooooooooo where are you?
Well, but if you like to do animations some Video editor Skill should be nice.snorky wrote:
Its super easy to do a animation like you want just based on 1 single rendering and with all LightLayers rendered as a single file.
Then simply animate that images over each other like you like, setting the Layers to "add"
my test...Zom-B wrote:Well, but if you like to do animations some Video editor Skill should be nice.snorky wrote:
https://youtu.be/M_EAiXa7Xkk
Ah, nice! Is this based on one single rendering and animated later in a video editor?
yes yes!Zom-B wrote:Ah, nice! Is this based on one single rendering and animated later in a video editor?
I use virtualdub and a png files sequence
- Originalplan®
Nice vid.snorky wrote:yes yes!Zom-B wrote:Ah, nice! Is this based on one single rendering and animated later in a video editor?
Please try AE for video...it is build from ground up for stuff you want to use in your project.
But AE is not for free like VirtualDub!Originalplan® wrote:Please try AE for video...it is build from ground up for stuff you want to use in your project.
- Originalplan®
That's true...missed that crucial point.Zom-B wrote:But AE is not for free like VirtualDub!Originalplan® wrote:Please try AE for video...it is build from ground up for stuff you want to use in your project.
Can't that be done in Natron using exr light layers? Haven't seen it but it's free, maybe worth checking.
Users browsing this forum: Google [Bot] and 85 guests
