user bug: values multiplied by zero returnin extreme results
2 posts • Page 1 of 1
Post by CTZn » Fri Oct 31, 2014 3:48 am
edit: my mistake, there is no such Indigo bug. The shared code was duplicated into the parameter shader on which I worked quite some time until conflicts became obvious. I even halted my PC in order to repeat the said bug. I understood my mistake this Saturday night...
in fact, whole terms get ignored in definitions intermediary to eval(), wich in turn responds normally if modified.
Attaching file through a different device...
Re: Hard bug: values multiplied by zero returnin extreme res
Post by CTZn » Fri Oct 31, 2014 3:58 am
The shader is displacement. Values are multiplied by zero in several instances yet yield a differentiated output.
ISL bug - terms ignored in definitions.pigs
(378.4 KiB) Downloaded 109 times
Users browsing this forum: Ahrefs [Bot] and 3 guests
