Page 1 of 1
Blend with additive mode
Posted: Thu Nov 01, 2012 11:55 pm
by noldo
Is there a way to combine (blend) two materials in additive mode?
Re: Blend with additive mode
Posted: Fri Nov 02, 2012 12:08 am
by CTZn
Not as in an editing image software. I think that this, as you may think of it would break a condition for a realistic behaviour of the resulting material.
Now, what is it that you want to achieve ? There is perhaps a different way for that.
Posted: Fri Nov 02, 2012 12:47 am
by Zom-B
In the C4D Exporter you can blend ISL Shaders in using:
- multiply
- add
- subtract
maybe more could be possible?!
But the restriction here is as I said that atm only blending of ISL Shaders is possible, not a texture with another one for example...
Posted: Fri Nov 02, 2012 1:13 am
by galinette
It's possible to add to textures via ISL, as texture can be accessed by ISL. The result will be clamped to 1 in case of albedo (or diffuse) textures
Posted: Fri Nov 02, 2012 2:06 am
by noldo
No, no, I thought about the blend material in additive mode, a la Maxwell Render.
For example, a base material oren nayar, and a phong with black color, only for subtle specularity.
Posted: Fri Nov 02, 2012 2:11 am
by Zom-B
atm Indigo has a Blend material that is linear and can be controlled by texture.
But A, B and C is available for tweaking too...
Posted: Fri Nov 02, 2012 3:26 am
by CTZn
noldo wrote:For example, a base material oren nayar, and a phong with black color, only for subtle specularity.
In this case you want the phong albedo to be the same than the one used by the Oren-Nayar material, and control the specularity strength with a constant blend value between both.
Posted: Fri Nov 02, 2012 4:13 am
by galinette
noldo wrote:No, no, I thought about the blend material in additive mode, a la Maxwell Render.
That's clearly an interesting feature for that use, and it's true that regular blend make only dull materials. Only workaround is to have a very reflecting phong (high IOR) and blend it slightly to another material. But that's not perfect.
Posted: Fri Nov 02, 2012 4:18 am
by OnoSendai
There's a coating material for this purpose that will be released soon.
Posted: Fri Nov 02, 2012 9:56 am
by noldo
OnoSendai wrote:There's a coating material for this purpose that will be released soon.
Indigo is a beautiful piece of software...
Posted: Sun Nov 18, 2012 2:55 am
by Pibuz
Indeed!
Cool varnished materials, yay!
