Large Resolution Windows Lockup
- fractal.design
Hello,
If I try a huge resolution render, Indigo uses all the available memory resources, locking up Windows.
Maybe this function call can work: GlobalMemoryStatusEx
Hope that helps.
Oliver
Hope that helps.
Oliver
Re: Large Resolution Windows Lockup
yes, to high SubDiv or SuperSampling can crash your System :/
If there is a possibility that Indigo crashes instead (or at least stops working and tells you why!),
then you have my +1
then you have my +1
Troll : use a good operating system
More seriously, I am surprised that in 2012 you still can crash a system by allocating too much memory in a standard app. Does working under a standard user account prevent this?
Etienne
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
If someone finds a simple solution that you can apply to multiple programs I'd be happy (DAMN YOU 3DSMAX). It's natural no matter how much memory you have, you always want to push the limits =P
But on topic, just for indigo it would be useful to prevent data loss/system restarts.
- fractal.design
Yes, apparently it is still possible.
I haven't tested with a standard user account..
There is that function which coders must implement to check resources: GlobalMemoryStatusEx
MacOS performs a similar test automatically.
or so I have been told.
Anyway, hope that helps.
Yeah, Windows 7 does a rubbish job of this. If a program takes too much memory, then Windows will start paging it to disk, and then grind to a complete halt, allocating so few cycles to the GUI that a reset is required. Pretty lame for 2012.galinette wrote:Troll : use a good operating system
Etienne
Adobe has a setting for AE and PS where you choose how much RAM the program is allowed to allocate max...
But wouldn't be a general "paging to disk" forbidance for Indigo possible to halt all operations and release RAM before doing so?
I also dislike about Indigo, that closing it during scene build up waits for finishing that, instead of a clean direct shut :/
Bumping an old topic and wondering if anyone has found some kind of solution yet.
Yeah it's really scary to hear and see windows growing the virtual memory in all extents, too much stress for the system and its owner.
- PureSpider
I had this too often with C4D and too high subdev settings or similarOnoSendai wrote:Yeah, Windows 7 does a rubbish job of this. If a program takes too much memory, then Windows will start paging it to disk, and then grind to a complete halt, allocating so few cycles to the GUI that a reset is required. Pretty lame for 2012.
I wrote a small script in AutoHotkey to kill apps when memory utilization hits the desired value. It's my first real attempt at any scripting language so the blocks and syntax are really messy - I encourage people to read it, edit it, play with the settings, test it with different apps, etc. and to post your version here -- The main thing is that it works. I figured noone was going to make it for me so I might as well try. I am sure using a real programming language would have better results given the greater control you have over windows memory handling, etc.
Script attached in rar (.ahk).
To run the script you will need Autohotkey:
Runs as a little H in the taskbar (can right click to exit, etc)
http://www.autohotkey.com/
The script uses sysinternals pskill.exe:
http://technet.microsoft.com/en-us/sysi ... s/bb896683
The PSTools.zip will contain all the ps tools. You only need pskill.exe. You can place it in the same folder as the script or for tidyness sake in your windows folder.
If memory is filled before the script can kill the application, windows will become unresponsive for a period of time. The application has been killed, windows just takes a long time to recover from 100% memory utilization, on my system that can be 5-10 minutes. This happens because memory can fill quicker than the script is looping, if it happens a lot, set the kill level % lower.
I suggest testing it at lower kill levels to begin with to make sure the script can run pskill.exe (some anti virus programs won't let it run, sometimes windows path variables aren't set properly). To test you can just set the level to 1% and open indigo.exe, it should be killed right away.
Shift+Esc to exit at anytime
Shift+F1 to kill the selected app at anytime
I will add a fancy interface in time that will be much more useful (less annoying) than the popup boxes and tooltip.
- MemKiller_alpha.rar
- (1.09 KiB) Downloaded 185 times
Just a warning about the pstools, they are a sensitive material that can be used remotely. They are network tools really. I miss pskill.exe (when MS kill.exe wouldn't do).
Cool idea ENSLAVER, may do.
