Page 1 of 1
[BUG] 8Bit PNG output Gamma issue
Posted: Thu Jan 05, 2012 9:00 pm
by Zom-B
Hey Guys, I just did a recent test with EXR vs PNG output.
Doing that I recognized that Indigos PNG Output seems is different to EXR @ gamma 0.454545454.. => 8bit
Click for bigger view!
It seems that Indigo does gamma correction of the image after converting to 8bit!
Doing so in Photoshop I get a 99.5% similar result to the PNG output!
Isn't it correct and "lossless" to do so in the 32bit image and convert then to 8bit?!
Re: [BUG] 8Bit PNG output Gamma issue
Posted: Fri Jan 06, 2012 6:28 am
by StompinTom
Zom-B wrote:Hey Guys, I just did a recent test with EXR vs PNG output.
Could that perhaps be the source of some of the banding problems we've experienced as well?
Posted: Fri Jan 06, 2012 6:35 am
by Zom-B
StompinTom wrote:Could that perhaps be the source of some of the banding problems we've experienced as well?
Something that could be checked quite easy :)
Any Thread here about this, maybe with some example file to test?
Posted: Fri Jan 06, 2012 8:34 am
by FakeShamus
here are some tests I made to show the banding I've been dealing with. just flat sky with camera tonemapping (color is super-exaggerated, of course, to highlight the problem).
I tested converting the gamma of the tonemapped exr in photoshop both before and after downgrading the file to 8-bit rgb and you get similar banding either way. (2nd image)
the main thing that seems to be missing in Indigo is a dithering function. If you convert to 8 bit from 32 in photoshop, using dithering, it eliminates the problem (3rd image). you get a slightly rougher grain structure if you convert to 8bit first and then do the gamma correction, but still, no banding.
