Looks like the envmap is mapped around the 0,0,0 coordinates?
That means you need the camera at 0 to avoid distortions.
Shouldn't the envmap map around the camera to get correct spherical mapping and lightingings?
Envmap position
Re: Envmap position
That's very strange... Envmap is supposed to be at infinity, the projection should not depend on camera position...
Are you talking about camera z position or pitch?
Etienne
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
Re: Envmap position
Camera Z pos.
The more it's moved up or down the more the env gets distorted, just like if you map it to the inside of a sphere in your modeling app and move the camera up or down.
Re: Envmap position
Since the environment is a finite sphere indeed, moving it with the camera would affect the lighting of the scene.
Its size may be relative to the scene bounding box, so one should not notice this under a normal usage.
Re: Envmap position
OK
This is a strange way of describing envmap : an infinite sphere should be used.
If finite, it should be centered on the camera.
Etienne
Etienne
Re: Envmap position
Then lighting would change along with the camera position.galinette wrote:If finite, it should be centered on the camera.
I am not sure that Indigo has always used a finite sphere for environments. A real infinite source sounds more elegant indeed, any technical consideration disregarded. I'm not educated enough
Re: Envmap position
Sure... this would be a mess for animationsCTZn wrote:Then lighting would change along with the camera position.galinette wrote:If finite, it should be centered on the camera.
Re: Envmap position
However the issue I am running into currently is with aligning the Indigo and env map suns, one more argument in favor of a fixed world position.If finite, it should be centered on the camera.
Either as a permanent option, or forced if the sum material involves the sunsky material.
As a permanent centering option, could be among: "camera", "world" (pos either origin), "bounding box".
A true infinite source is still ideally prefered.
