Mini servo actuator
Mini servo actuator
after a lot of test and work, here is my finished artwork.
regards, Phil
regards, Phil
Thanks for your comments,
@zsouthboy
The ribs on the wire is a modeling problem, I just decide to let them so, because some imperfections gives more realism
@OnoSendai
Perhaps there is here a normal problem, but not on the wire, on the aluminium material.
I used here the sand blassed texture for the aluminium, but I never get the expected result.
I played with all parameter, nothing worked as expected.
After 1 or 2 hours the result looks good (for the aluminium) but after 1 day the interesting effect is gone
Perhaps Indigo just smooth too much in this case?
Noise should still be there in the aluminium material.
I am still investigating this point with other parameters, and so on
Thanks to all,
regards, Phil
@zsouthboy
@OnoSendai
Thanks to all,
regards, Phil
yes the material is a bump map, here is the code for information:
Regards, Phil
<material>
<name>Alu_bumped</name>
<phong>
<nk_data>nkdata/Al.nk</nk_data>
<exponent>900</exponent>
<bump_map>
<uv_set>uv</uv_set>
<path>noisemi8.jpg</path>
<gain>0.002</gain>
<exponent>1.0</exponent>
</bump_map>
</phong>
</material>
<material>
<name>alu_bumped.2</name>
<phong>
<exponent>700</exponent>
<bump_map>
<uv_set>uv</uv_set>
<gain>0.003</gain>
</bump_map>
</phong>
</material>
Users browsing this forum: Majestic-12 [Bot] and 27 guests
