One A Day Keeps The Doctor Away.
- kwistenbiebel
Hi all,
A render of a tasty model posted at Sketchucation.
I took the model and fooled around with it, rearranging the parts and placing them on a curved ground surface.
Material setup isn't fancy. I started from the Skindigo presets and moved some numbers, so it could be done a bit more 'in depth'.
For me, it was a good opportunity to try some studio light.
Lighting consists of two vertical emitting surfaces left and right and a LDR for reflections. Layer blending is a nice feature to control the levels.
Rendered using Skindigo (Indigo 1.1.15 x64).
cheers,
Kwistenbiebel
cheers,
Kwistenbiebel
Last edited by kwistenbiebel on Tue Nov 10, 2009 11:19 pm, edited 1 time in total.
- Doug Armand
Re: One A Day Keeps The Doctor Away.
I'd say thats pretty impressive - apples look good enough to eat
Doug
Doug Armand
Doug Armand
- pixie
Although the blade is not that sharp, I bet if you keep it close enough to the doctor you will keep him away...
Cool pics!
Cool pics!
I like the surrealism. What tonemapping function did you use?
I think we're seeing the wrong side of the blade.pixie wrote:Although the blade is not that sharp, I bet if you keep it close enough to the doctor you will keep him away...
samlavoie.xyz
- kwistenbiebel
Thanks guys
And then there are the phone calls...aargh, those phone calls.
I usually use the Camera tonemapping, but when having multiple light sources, it is sometimes a bit more difficult to control the intensities of the lights.
Yeah, first I used the spoons , but he was countering my moves all too easily. Gosh, are those doctors persistent.pixie wrote:Although the blade is not that sharp, I bet if you keep it close enough to the doctor you will keep him away...
Cool pics!
I used the default Reinhard tonemapping of Skindigo and increased the 'burn' a little (by lowering from 6 to 3) and fiddled a bit with the 'Pre-scale' value, although I don't remember the exact value.benn wrote:I like the surrealism. What tonemapping function did you use?
Q: "how do you like them apples?"
A: "with more polygons, please"
otherwise totally awesome!
Yes I thought it looked reinhard. Apart from that it looks great!
Maybe we should add a camera response function to reinhard, just a default awesome one so it doesnt look quite so plain.
Nice pictures kwistenbiebel! You can always use Motiva RealCamera to have Camera tone mapping.
take care
psor
take care
psor
"The sleeper must awaken"
- kwistenbiebel
So what is wrong with the tonemapping I used?benn wrote:Yes I thought it looked reinhard. Apart from that it looks great!
I checked on different monitors, and it looked ok to me.
