Scale Model: layer blending
- kwistenbiebel
Re: Scale Model: layer blending
That's exactly how I am fixing the vignetting now
- pixie
You can fix it the way you would in the real world, by choosing the biggest f/stop available. The lower the aperture the less vignetting.Pibuz wrote:The control of the vignetting during the rendering is one of the things I requested. I hope they will introduce a parameter or something soon, sometimes, vignette is annoying. There's no way to fix it inside Indigo, you have to apply a PS filter under filters->distortion->lens correction (CS4). There's a tool to modify the vignetting..
That is, a smaller aperture radius will generate a more pronounced vignetting.
One get a smaller radius by increasing the f/stop setting though
- pixie
CTZn wrote:That is, a smaller aperture radius will generate a more pronounced vignetting.
Smaller radius smaller aperture bigger f/stop?
eeyup that's what I mean... aperture is defined by a radius, it's a distance expressed in meters.pixie wrote:CTZn wrote:That is, a smaller aperture radius will generate a more pronounced vignetting.
f/stop in another hand is a ratio comparing two distances if I'm correct, it has no unit.
[removed attached image]
- pixie
I made a quick test one for the biggest and another for the smaller f/stop
F1 F64
F1 F64
The twop images look identical ? Aren't both using a fstop of 64 ? There's something fishy in your comparison pixie I think.
- pixie
That was what surprised me too... I assure you that both were taken as advertised, I had to tweak the tonemapping so that they could despite the aperture size have the same light exposure. So they have also quite different iso and ev adjust accordinglyCTZn wrote:The twop images look identical ? Aren't both using a fstop of 64 ? There's something fishy in your comparison pixie I think.
Weirdo...
Can you provide the dimensions of the bridge in your scene plz pixie ? I must test that out... or just replace the bridge with it's textured bounding box (vertical bandings, to see fov details) and send the pigs.
- pixie
I've uploaded it on Leonardo's bridge thread, go check it outCTZn wrote:Weirdo...
Oh yes thanks, I started an argument then lost myself
I'm sorry I drove OT kwistenbiebel, meeeh...
edit: plus, I'm not sure I didn't tell bullpacks. No one to watch me
