My kitchen (A bit blurry)
10 posts • Page 1 of 1
tobak30
Post by tobak30 » Mon Apr 30, 2007 11:38 pm
After 35 hours of rendering I call it finished. don't wanna render it for ever. t is still blurry. I tried to remedy that with selective gaussian blur and a bit resizing. original is 1200*1000. Modelled in blender and exportet using blendigo.
I would like too thank kram for all the help I have recived with this scene.
zsouthboy
Post by zsouthboy » Tue May 01, 2007 2:07 am
What exactly is "blurry" about it?
Why did you try to compensate for percieved blurriness by ... blurring again?
Post by Kram1032 » Tue May 01, 2007 3:12 am
you meant noisy, right?
If you really meant blurry, try to increase f-stop!
You used f-stop 8.
I can't find the problem with the glass-plate....
WHAT THE HELL causes the black pattern???
tobak30
Post by tobak30 » Tue May 01, 2007 3:17 am
Soprry I meant noicy, not blurry. my bad. And what black pattern are you talking about kram? If you mean the "frame" thats outside. I changed the camera position a tiny bit to the right before rendering it.
Post by Kram1032 » Tue May 01, 2007 3:21 am
Nope, I know the scene, don't forget that ;)
The outside part isn't black, it's dark gren, as supposed to.
the plate, that looks violet in the blender-scene but is transparent, here.
You clearly can see a black pattern on it...
But maybe, "outside" is correct anyway: it COULD be a reflection from there...
which would mean, that glass in the "door" would help :D
Post by StompinTom » Tue May 01, 2007 6:27 am
could be a normals issue. recalculate normals outside.
Post by Kram1032 » Tue May 01, 2007 10:37 am
I KNOW the scene, the normals are fine!
tobak30
Post by tobak30 » Tue May 01, 2007 10:59 am
Oh I know what it is. it is a drinking glass that is in front of that bowl
Post by Kram1032 » Tue May 01, 2007 9:56 pm
at hte begininning, the room was 55._something_ m high and I reduced it to be 2.4m... But there still can be some problems with the single objecs....
Way less scale-problems than before, however xD
Post by Kram1032 » Thu May 03, 2007 5:51 am
ok, tobak, you're right:
the black thing is the glas infront of the bowl.
it has reversed normals :?
Please select it, go in Edit mode, select all the vericles and press [Ctrl]+[N]
it should work, then...
when ALL the normals are wrong, it's hard to see the mistake :?
