Two culinary pieces (I was hungry...)
the cloth simulations are not easy to do in blender, you have to wathc for a lot of traps!
Really nice composition and greeat use of DOF! The cloth looks really good. However, I think the cups don't look like cermaics but ceramics with a thick layer of translucent paint on them. Is that on purpose?
Also I think the bump is a little too strong.
But not to take anything away from you. Great work!
- drBouvierLeduc
Danke, danke,
Mr Carnivore: The cups are just a simple white phong material, but the effect probably comes from a too high exponent. I'll try again with a lower figure. It's also hard to get the optimal value for the bump map, as the surface only appears clearly after a long time rendering. I was thinking of playing with the bump texture instead, perhaps blur it a little to make the grooves and bumps a bit softer. I'll let you know how it works.
It's nice. But the lighting on the backward in the first pic looks strange. The light seems to come from above the piece of furniture, but the lamps seem to be placed somewhere neer the chairs.
If the lamps are really so closed to the piece of furniture, then, it might be impossible to open then cupboards without bumping into it
____
edit : ooops My comment above is a little bit outdated, I didn't see there were two pages.
The picture with the cups and the cookies is excellent !
____
Here is another version with lower exponent on the cups (2000 instead of 100000) and a heavily blurred bump map. Somehow I like it less than the first. But I've also exported and reimported the mesh of the cup in focus which seemed to have a slight normals smoothing problem in the inner rim. I've also uploaded a bird's eye view of the scene (with the original, strong bump map) to show the general architecture.
Stur: You may have this impression because I used a very strong zoom in the kitchen pic, which tends to flatten the image. I could post a wireframe view of the mesh later if you're interested.
- im1174482923.png (812.48 KiB) Viewed 3376 times
- im1174469177.png (772.32 KiB) Viewed 3376 times
