Originalplan®'s rendering corner
Originalplan®
Re: Some renders for CLASSICS & PATTERNS
Post by Originalplan® » Mon Jan 23, 2017 7:14 am
...some update on this front also.
Post by Oscar J » Tue Jan 24, 2017 6:34 am
Nice, but I'm not sure I understand the ground mat. :)
Originalplan®
Post by Originalplan® » Tue Jan 24, 2017 7:08 am
Well something like in the pic below just more wet & dark.
(The green below the projected image comes from Neons..the rods you see going horizontally across. )
Just experimenting...
For more natural not so artistic picks >> visit
Motor oil on wet asphalt.
Post by Oscar J » Tue Jan 24, 2017 7:36 am
Ah, ok. Are you doing it using interference?
Originalplan®
Post by Originalplan® » Tue Jan 24, 2017 8:24 pm
Oscar J wrote: Are you doing it using interference?
No, but i should... since some ISL does not show up on GPU yet.
( hint* for a 25/s moving image would be nice to have just for speed. ;) )
Right now the mat is a small bit of ISL on the thickness front on a phong mat.
And that is blended together in c4d with c4d's native noise in a separate mat.
So there is 3x noise on roughness, bump, displace..etc and that is blended together with the same negative noise = for the blend mat. Hope makes sense..
Anyway kinda the scenenery should be some dark bit futuristic environment ....since the whole thing YAMAHA has revolves around " the dark side of Japan "
(1)
(2) ...some idea base.
Originalplan®
Post by Originalplan® » Fri Feb 10, 2017 4:03 am
Please Don't Touch the Be@rbrick :!:
Down sampled from 5K
Zalevskiy
Post by Zalevskiy » Fri Feb 10, 2017 4:24 am
Good detail fingerprints!
When there is an option bear mummy? Egypt, Pharaoh :twisted:
Originalplan®
Post by Originalplan® » Wed Feb 15, 2017 3:54 am
Will do one @Zalevskiy not sure when but will do. : )
Originalplan®
Post by Originalplan® » Sun Mar 19, 2017 8:33 am
Kept you waiting, huh? 8)
Wet Be@rbrick.
GPU still.Probably should do a BiDir one.
Originalplan®
Post by Originalplan® » Mon Mar 27, 2017 6:53 am
Molten Be@rbrick.
Post by zeitmeister » Mon Mar 27, 2017 9:23 am
Hehe, nice! Reminds me of the gumballmachines in my youth... :-)
Originalplan®
Post by Originalplan® » Sun Apr 16, 2017 8:06 am
@zeit Thanks! :)
Originalplan®
Post by Originalplan® » Sun Apr 16, 2017 8:07 am
King crab.
Testing those Light layers... :wink:
Originalplan®
Post by Originalplan® » Tue Apr 18, 2017 7:52 am
The Julienne Be@rbrick.
Originalplan®
Post by Originalplan® » Sun May 14, 2017 6:54 am
Polystyrene Be@rbrick.
Users browsing this forum: No registered users and 124 guests
