Project Description: This is porch house located on a small horse farm in rural Tennessee
Renderings: Model built in Revit then exported to Sketchup w/ 2D landscape. Used env map. Interior-9 light layers. Exterior- over saturated illustration effect..Again could use better textures or learn how to instance grass, trees, etc...it's at a big learning curve for us.
Post Processing: Saved at least 5 different EV's then processed as HDRI in Photomatix Pro & then again in Photoshop.
Real Project #2- Rural Porch House in Tennessee
Re: Real Project #2- Rural Porch House in Tennessee
Congratulations! I find the indoor shots warm and cozy: very well done!!!
..the outdoor shots are a little poor instead, maybe it's just something you have to learn (btw, I have to learn it myself ). In the EXTERIOR1 the photoshopped trees do not match with the general ambience and so they look kinda patched over the image. In EXTERIOR2 the grass patch is waaaaaaay too repetitive: in these cases more than 3d grass it's good to have a very nice grass texture as a base and then refine it in photoshop.
Lovely interiors, though I`d axe the vignetting. Lately I`m not such a big fan of vignetting anymore...
Pibuz, Stompin Tom,
Thanks for the comments.
We have a long ways to go with learning with all aspects!
Hey how do you guys do this level of photoshop ? You already have some photoshop scenes ready or what ? And you just put your render in the photoshop scene and then edit a bit here and there ?
If not then how do you make the whole scene besides the render ?
Thanks for the question. That's a very.funny question for me because there is very little PS used. I save several Indigo exposures at 1/2 stops (.5 ev) then imported the whole range into a HDR (tone mapping) photographic program called Photomatix which blends the exposures together & allows you to adjust different aspects of the image. The original intent was to just gain good exposure from under & over exposed images like real photos. However, some of the adjustments allow you to do some pretty strange, & initially interesting (but now not) over saturated images. The experiment was to achieve an over saturated illustration like effect like cheap Christmas cards. If I actually knew how to use PS it may have come off more interesting!hemantchhabra wrote:Hey how do you guys do this level of photoshop ? You already have some photoshop scenes ready or what ? And you just put your render in the photoshop scene and then edit a bit here and there ?
Everything in these images is in the model. All vegetation is 2D face me components in the model.
The only thing done in PS was smart sharpen at .5 & the over used vignetting with a curves layer.
Thank you
FYI you can save image as EXR in indigo and tonemap that, instead of saving multiple images at different stops.
Thanks for the info. I will have have to give it try.
Users browsing this forum: Ahrefs [Bot], Majestic-12 [Bot] and 90 guests
