gpu - black widow - bad drivers
Building OpenCL scene data.
Num buffer layers: 1
Master buffer size: 42.923 MB
Settings:
Image width: 1280 px
Image height: 720 px
Supersample factor: 2
Internal image width: 2576 px
Internal image height: 1456 px
Verbose: false
Image save period: 3600 s
Splat filter: FastBox
Downsize filter: mn_cubic, blur=1.000, ring=-0.000, support=3.200px
Metropolis: false
Bidirectional: false
Aperture diffraction: false
Post-process diffraction: true
Auto setting number of threads to 8.
Finished initialisation (Time Taken: 0.16 s)
AutoFocus: setting camera focus distance to 0.099 m.
OpenCL code for 'specular' on Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz built. (from cache, elapsed: 0.04769 s)
OpenCL code for 'phong' on Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz built. (from cache, elapsed: 0.04760 s)
OpenCL code built: (elapsed: 0.04848 s)
OpenCL code for 'specular' on Radeon RX 560 Series, Radeon RX 560 Series built. (from cache, elapsed: 0.07489 s)
OpenCL code for 'phong' on Radeon RX 560 Series, Radeon RX 560 Series built. (from cache, elapsed: 0.07295 s)
OpenCL code built: (elapsed: 0.07584 s)
Starting threads... (num threads:
Starting render thread. (RNG seed=0)
Optimised OpenCL code for 'specular' on Radeon RX 560 Series, Radeon RX 560 Series built. (from cache, elapsed: 0.005879 s)
Optimised OpenCL code for 'phong' on Radeon RX 560 Series, Radeon RX 560 Series built. (from cache, elapsed: 0.01002 s)
Optimised OpenCL code for 'specular' on Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz built. (from cache, elapsed: 0.02729 s)
Optimised OpenCL code for 'phong' on Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz built. (from cache, elapsed: 0.02645 s)
Re: gpu - black widow - bad drivers
all the same, but bench is working
Does the scene render fine with CPU PT?
Logs looks correctly..
May be 4.064 ver. will works? (like bench)?
Is there any way start render with indigo_console from *.pigs?
- indigo_gpu_info.txt
- (6.43 KiB) Downloaded 194 times
Zom-B wrote: ↑Sun Sep 08, 2019 1:05 amwhat Indigo version do you use?
Try the latest: 4.4.1
viewtopic.php?f=1&t=15253
Great it works!
Great it works!
I had the same problem, 4.4.1 fix it.Zom-B wrote: ↑Sun Sep 08, 2019 1:05 amwhat Indigo version do you use?
Thank u very much!
