Apologies, for asking something that I saw has been addressed before,...BUT...those posts unfortunately did not answer my problem/issue>
I am new to the program. I downloaded the RT version (plugin for Sketchup, on a Win 64 system), Went through license key steps, no problem...all went well, key was accepted.
When I went to run a render....The header at the top says "Indigo Render (trial version)"......I check the Licensing ...and it tells me I am using a "registered version of Indigo" licensed to me. So what is the deal with the "trial version" note in the header bar.
Next problem....I go to run a render....I have watermarks, all over the screen/render. I go up to the "Options > Interface And Render >Watermark" section...the button is "OFF"/not checked....so I should not be getting watermarks.
This is all most annoying...any help would be greatly appreciated.
Watermarks in render...AND "(trial version") in header?
Re: Watermarks in render...AND "(trial version") in header?
Make sure you have Indigo RT installed, not Indigo Renderer (full).
How do I check that?
I used the download provided, when I paid for RT....so I assume that is what I would have installed. License also says it is approved. Would assume that wouldn't be the case if it was the full version.
Thanks.
Thanks.
Problem resolved. All good now. I went and did a re-install.
