Image projector
Re: Image projector
Hi
Excellent result, as you did?
Re: Image projector
you understood me wrong, this is photo and i want make this effect in Indigo
Re: Image projector
Tricky challenge - I would have tried using a small emitter, contained in a box which has a hole in it with that particular shape. For that cone you will need a fog volume - search for the fog material in the material database.
Re: Image projector
Be wary that as in every renderer, volumetric effects are the more costly.
You may want to actually model the carved pyramid and use a transparency map, perhaps make it an emitter or compose it with a camera-diffracted, light emitting version. I'm making this out but that depends on how urgent the need is.
Oscar proposed the best solution though, as in simulation.
