Hell and help :)
Come here for help & support.
8 posts • Page 1 of 1
dtoxic
Hell and help :)
Post by dtoxic » Sun Mar 27, 2011 6:34 pm
ok here is the problem i have 3ds max 2011 and indigo 2.6.1 beta (i think) now i just cant seem to figure out how to work with IES light i created a target. photometric light selected web distribution,selected IES profile and nothing...then i thought id try with emitter material but i just cant seem to find where to select ies in the material editor or what kind of map to add well dont blame the newbie :P cant someone point to me what to do with screen shots if posible i have looked at this http://www.indigorenderer.com/forum/vie ... =19&t=7430 but where are emitter atributes anyway if anyone can halp me out would be cool :)
ENSLAVER
Re: Hell and help :)
Post by ENSLAVER » Mon Mar 28, 2011 12:55 am
dtoxic
Post by dtoxic » Mon Mar 28, 2011 1:03 am
ENSLAVER wrote:I could be wrong, but I'm not sure the max plugin has IES functionality yet.
lol good to know i was about to smash my head on the keyboard :) thx btw
Post by suvakas » Mon Mar 28, 2011 1:40 am
Hi dtoxic,
Maxigo has IES support (just tested and works fine here). Steps you describe seem to be correct too.
Did you have your camera and/or tonemapping set up correctly? Maybe your light was too weak or smth?
Try with a single photometric light and reinhard tonemapping.
ENSLAVER
Post by ENSLAVER » Mon Mar 28, 2011 9:14 pm
Ha, I was looking in the wrong spot for them too, I kept looking in the emitter material options.
Here's I got them to work -
Create > lights > photometric lights > target or free
Modify panel > general > Light distribution (type) > Drop down to Photmetric Web, then choose an IES file.
Here are two IES files that I know work w/indigo, use these to test =)
http://dl.dropbox.com/u/6928552/01.ies
http://dl.dropbox.com/u/6928552/02.IES
dtoxic
Post by dtoxic » Tue Mar 29, 2011 12:51 pm
thx people got it :) keyboard survived as did my head :P thx again :)
Jay-ko
Post by Jay-ko » Fri Mar 15, 2013 3:24 am
I am sorry but "where" exactly?
I follow this:
http://www.indigorenderer.com/documenta ... ies-lights
and that:
and again that:
http://www.indigorenderer.com/forum/vie ... 0&start=15
and finally that:
http://www.indigorenderer.com/forum/vie ... =9&t=11889
If i create a photometric light in 3ds max and add an IES files i have a Null result. (not exactly i have 1 pixel white where i have the center of my light :D )
even if i tweak my exposure control.
even if i choose an other ies file from http://www.indigorenderer.com/dist/ies-profiles.zip
If i create a plan with a indigo material i don't find where i need to put the link to the IES file.
So i probably misunderstanding something.
If i use a geometry to distribute the light, like a tube for example.
can i link an igm with an IES definition?
If it's correct (it seems no but..) can you send me the link to the technical documentation, i don't know how to do that in this kind of igm:
<scenedata>
<material>
	<name>lamp</name>
	<diffuse>
	 <albedo>
	  <constant>
		<rgb>
		<rgb>0.5 0.5 0.5</rgb>
		<gamma>2.2</gamma>
		</rgb>
	  </constant>
	 </albedo>
	<base_emission>
		<constant>
		<rgb>
			<rgb>150000.0 150000.0 150000.0</rgb>
			<gamma>1</gamma>
		</rgb>
		</constant>
	</base_emission>
		<layer>0</layer>
	</diffuse>
</material>
<layer_name>
		<layer_name>Layer-0</layer_name>
		<layer_index>0</layer_index>
	</layer_name>
</scenedata>
Thank a lot by advance for your help :)
errare humanum est
Jay-ko
Post by Jay-ko » Fri Mar 15, 2013 3:37 am
Find here a 3D and an IES file from Phillips with all the stuff we need for that
http://www.ecat.lighting.philips.com/l/ ... 958003_eu/
The ligth is distributing by smalls polygone squares.
With a color temperature at 3000 K; it provide 2800 Lm and 95 Lm/W Luminous efficacy.
errare humanum est
