my first indigo animation
13 posts • Page 1 of 1
dougal2
Post by dougal2 » Sat Dec 30, 2006 7:37 am
http://ftlfm.com/doug/video/bounce.avi (xvid codec, 430kb)
only 36 frames, one minute render per frame. denoised (temporal) in virtualdub.
it's probably not that interesting to watch - it was mostly an exercise in creating the scripts (2 batch files) to make it possible.
Bandar
Post by Bandar » Sat Dec 30, 2006 7:57 am
Very nice... looks like an old 8mm.
DaveC
Post by DaveC » Sat Dec 30, 2006 8:00 am
One minute per frame isn't bad, is it? Considering it's un-biased. It would be great to see something more substantial done with it. Nice work.
Behrendt
Post by Behrendt » Sat Dec 30, 2006 8:29 am
Like It :shock: :)
Post by CTZn » Sat Dec 30, 2006 8:40 am
Yeah that's fun !
BZ Win
Post by BZ Win » Sat Dec 30, 2006 10:00 am
Wow! Cool!
By any chance can you post the batch file(s) used? I need to do something like this, but I have no idea how to go about doing it.
dougal2
Post by dougal2 » Sat Dec 30, 2006 10:40 am
ok then, here we go. assuming you're using blender...
step 1:
have a directory structure like this:
(actually, this isn't strictly necessary, but i like to keep things tidy)
c:\renderroot\scenes\animation\
c:\renderroot\indigo\
step 2:
use the blender exporter "Export Anim" button and put the xml files in the animation directory.
BE WARNED - if your scene contains lots of things, or complex meshes you WILL use a lot of disk space here. You will generate 1 xml file per frame.
You can save a little space by having a separate materials xml as well - all the frames then will use the same materials xml file.
step 3:
put this batch file in the indigo directory, along with the indigo.exe and suporting files.
makeanim.bat:
@Echo off
REM --   SYNTAX:
REM --   makeanim xml\dir animbatchname
@echo @Echo off > %2.bat
FOR %%G IN (%1\*.xml) DO (
	@echo @echo Starting %%G... ^&^& start /belownormal /wait indigo -halt %%1 %%G -o %%G.png >> %2.bat
step 4:
then call makeanim.bat with 2 arguments. the first is the directory where the xml files are stored, and the second argument is the name of a new batch file which will be created to actually do the job.
c:\renderroot\indigo\makeanim.bat ..\scenes\animation render_my_anim
you can use relative or absolute paths. i prefer relative, since i keep all my render files together anyway.
step 5:
then run render_my_anim.bat with just one argument - the number of seconds to render each frame for:
c:\renderroot\indigo\render_my_anim.bat 60
Also worth doing is lowering the image_save_period in the inifile.txt so that indigo gets a chance to save the image a few times before it is killed and moves onto the next frame.
All your PNGs will be rendered into the same directory as the xml files as
step 6:
from there you can import into something (virtualdub) that will compile a video for you.
step 7:
there isn't one. you're done.
I hope this helps. feel free to post this method elsewhere in this or other forums.
One last thing to note is that i had problems running makeanim when the files were on a network drive - the FOR command kept skipping files.
For this purpose i've made a local copy of indigo so that the whole anim renders on one machine.
You could of course move some of your xmls onto another machine and render the animation piecewise.
Doug.
DaveC
Post by DaveC » Sat Dec 30, 2006 10:59 am
You wonderful, sharing person :D
neepneep
Post by neepneep » Fri Feb 16, 2007 12:50 pm
I vote dougal2's post in this thread for official sticky-status....
edit: :D
Dacksoldier
Post by Dacksoldier » Mon May 14, 2007 8:06 am
can you post an example of the render_my_anim.bat file so i can just write it myself cuz i end up with just
@ECHO off
in the resulting file
dougal2
Post by dougal2 » Mon May 14, 2007 8:25 am
Dacksoldier wrote:can you post an example of the render_my_anim.bat file so i can just write it myself cuz i end up with just
@ECHO off
this is becuase makeanim.bat didn't find any .XML files.
I wrote this before the file extension change to .IGS
open up makeanim.bat and change xml to igs and it should work.
0.7+ compatible:
@Echo off
REM makeanim xml\dir animbatch
FOR %%G IN (%1\*.igs) DO (
	@echo @echo Starting %%G... ^&^& start /WAIT indigo -halt %%1 %%G -o %%G.png >> %2.bat
beware though, that -halt time doesn't seem to work properly. (just so happens I was testing this last night - with 0.7final). Not sure how 0.8 will behave.
EDIT: You also might want to add /BELOWNORMAL after /WAIT ;)
Dacksoldier
Post by Dacksoldier » Sun May 20, 2007 4:44 pm
kk ty sry for the long reply
Post by Kram1032 » Sun May 20, 2007 10:46 pm
I'd like to see such a scene with 0.8, as it's much faster :D
