It's a-me, Mario! -WIP-
- Polinalkrimizei
I decided to revive my old Mario-scene.
So here it is! Still on my todo-list:
-Fix the uv-map issue on the front corner. Not sure why that happens though, in the blender viewport and uv/image editor it looks absolutely seamless. Mesh is just a cube, slightly beveled, with blender subdivision of 6. I didnt use indigo subdivision cause that tends to mess up uv's sometimes...
-give the grass a lower exponent, looks like plastic right now. But on the other side I kind of like this look.
Comments, crits always welcome
- click for full-size
- Mario grass 3.jpg (344.85 KiB) Viewed 7826 times
Re: It's a-me, Mario! -WIP-
How was made the grass?
Etienne
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
I like the dof. Very nice grass.
Great idea and great scene, worth finishing it, add those wooden cubes and enemies!
- kikeonline
The grass is awsome!!
I like the contrast between cartoon and realism.
great! lets see the turtles and mushrooms.
- Polinalkrimizei
Thanks guys!
I really didn't think about adding more stuff to this scene, I considered the general composition as finished. But it could be fun to make enemies and boxes. Should they be "real" or "8-bit"?
@galinette: grass is done with blender's particle system. It consists of three modeled grass blades, a clover and a blossom. The grass blades were each instanced 1.000.000 times, randomly rotated and resized. Clover and blossom both have about 300 instances. So it really just consists of 5 light models and is quite easy to set up.
Another example here (I posted it in the simple renderings thread, not sure how to quote it):
http://www.indigorenderer.com/forum/dow ... p?id=10411
StompinTom also made some very nice examples of this technique somewhere here!
Hey Polinalkrimizei do u know any tutorials related to blender particles with instancing.
Now i just make small batch with particles - convert to mesh - hit Alt + D - grab rootatate jne.
But it doesnt look soo smooth on other tnan pefectly flat surfaces.
- Polinalkrimizei
@meelis: Tom's contribution made it clear probably. Apart from that I don't know any good tutorial...
The basic workflow goes like this: model a grass blade, model a ground. Add a particle system to that ground (I use "emitter type"), make it emit from faces, hit "random" and "even". Use "object" as visualisation, type in the name of your grass blade. Hit "bake". Hit "render".
And because that will look boring: play with the values for random rotation and size.
Hints: You may have to rotate your grass blade 90° x, y, or z to make its instances point to the right direction (upwards). Use "normal" as dynamic rotation if you have a very curved surface like in the mario picture.
If your grass is not dense enough: set up more particle systems on the same ground, and use a grass texture on that ground, don't make it brown. Did that in the image from the simple renderings thread to cover some holes
feel free to pm me if you have a specific question, but I won't be able to answer before the weekend probably.
If you have the option, allow for Indigo subdivisions but not for surface smoothing. It's the later messing UVs up, you must then hide their borders from the camera (two faces rings away from UV borders IIRC). It's advised with planar displaced surfaces like here !I didnt use indigo subdivision cause that tends to mess up uv's sometimes...
A funny image really, imho keep'em blocky it's part of the effect (but I'm getting old ).
I really like this one, the contrast between the 'pixels' and ground is beautiful - I like the grass how it is, it's realistic but still connected to Mario's world.
I can't help but see a mario game with this effect, I would really be slick!
Thanks Polinalkrimizei and StompinTom
- Polinalkrimizei
minor update:
uv-issue is much better, and now it's in high res to be my new wallpaper. First I was afraid that the grass would look ugly but it's actually pretty cool...
I made some Gumpas, the mushroom-like enemy type in blocky style. Some pictures are cooking. I'll have to remodel Mario, cause the gumpa is much more detailed = more pixels = much bigger. I am aiming for the NES-version of Mario now.
- Mario grass 4.jpg (563.75 KiB) Viewed 7440 times
- PureSpider
That is actually a LOL image already!
Very cool subject and..what an amusing game!
The detailing of the grass seems to me like Mario went out of the game, and was dropped just into the real world. That is a good subject by itself. Keep going!
PS. I can remember an old user posted some tests of plastic-y images of toys, btw. The style was almost the same. They were cute images, totally gallery worthy to me..
Users browsing this forum: Bing [Bot] and 33 guests
