Page 1 of 1
forgotten in a box
Posted: Tue Jul 01, 2008 6:43 am
by m.f.t.
hi all,
here's a simple scene i made in 3ds max
expecting something marvelous! to happen, i modeled the emitter as a helix.
i think the image should be 'clearer' esp. the bulb and the mirror
what do you think the problem is?
a) inappropriate materials
b) i am not patient enough :? (4-5 hours on an e6300) (SPP 1571)
c) a higher super sampling size should be selected (4 was used)
d) any other?
thx. in advance
Posted: Tue Jul 01, 2008 6:55 am
by pixie
Some thin fog perhaps...
Posted: Tue Jul 01, 2008 7:40 am
by m.f.t.
no, there's no fog... :/
Posted: Tue Jul 01, 2008 7:46 am
by Borgleader
m.f.t. wrote:no, there's no fog... :/
And that is why he suggested to add some?
Posted: Tue Jul 01, 2008 7:51 am
by BbB
Main emitter behind glass = looooooong render time. Let the rays roam freely.
Posted: Tue Jul 01, 2008 7:53 am
by zsouthboy
Sampling through a bunch of media is a nightmare, it's going to be slow no matter what.
Simplify the emitter as much as possible (1 triangle) is pretty much all you can do to help.
EDIT: BbB beat me to it.
Posted: Tue Jul 01, 2008 8:55 am
by m.f.t.
ok, you're right, a very simple emiter would do too, and glass being unnecessary, but it's a little bit experimental...
(please don't let me be misunderstood)
and i'm not making a comparison
but here's another render from another unbiased renderer.
it's not a test between two, since the scenes and materials are not identical, nor the render time but results are very different.
(though both uses glass and comlicated emitter geometry.)
Posted: Tue Jul 01, 2008 9:30 am
by suvakas
Super sample factor 4 ? Why? It only controls the AA. Setting it to 4 renders your image 4x the size it actually is. Leave it to 2 as it is by default. Also for scene like this use MLT not Pathtrace.
Posted: Tue Jul 01, 2008 11:02 am
by pixie
:) That's what I meant. You could use nk materials for the metal and see if it improves...
Posted: Wed Jul 02, 2008 10:06 am
by Kram1032
"non-Indigo" isn't quite informative. If you do a render in an other engine, you should post, which engine ;)
SSF 4 is quite unnecessary. go for 3 or even 2.
Also try to activate (will actually slow down the render but will make it look more realistic and maybe in this case better, earlier) aperture refraction... (bloom)
Posted: Wed Jul 02, 2008 7:04 pm
by m.f.t.
since i am quite new to indigo world, i hesiteted about mentioning the renderers name.
here, the non-indigo renderer is fryrender,
i think in this case, indigo is more realistic, but fry is somehow sharper.
when i got spare time, i continue to take renders, and try to improve the image (and learn more about indigo) =)
...and, about the fog, aperture diffraction, when i manage to get a good image i can go with them, but not now...
Posted: Thu Jul 03, 2008 7:33 am
by Kram1032
Well, The sharpness of your render heavily depends on your AA settings. ;)
Which filters do you use for splat and for downsize and what are the values for them?
