Great
If you want air scattering, go crazy and use the true-sky-model xD
18:00, Venice, which time of the year?
Evening exterior
- drBouvierLeduc
Hi all guys! And thanks a lot. No updates this time, sorry
drBouvier: thank you doc! It's always a pleasure to know someone like you likes one of my productions
Kram1032: hi Kram! This scene is set in july. We sketchUppers have a little bug concerning the times of the day and the day/time variables of Indigo: sometimes if you push your time a bit too much towards evening, the sky system start producing strange light effects, like violet sky for exemple.. So, i tried a not-so-late time, and i had luck, i see; perhaps i could try setting a later time, and see if it's kept or not.. Gonna try!
CTZn: thank you mate! You're right about the lights, so right. It's only that i have a kind of fear about burning the lights, as if there were no possibility to switch back to the unburned settings..I think it's a matter of psychology.. You're right BTW, i'm going to lit them up, maybe justa a little..
Woodie: you're right about the size of the waves, woodie. In sketchup we have no possibilities to have displacement modifiers for a surface or anything, so i used a sort of workaround physically modeling the water volume. I used a tool which i never used before for such a task, so i easily may have used that badly.. I'll try to re model the water: thanks!
for 18:00, july, it really looks pretty "late"... I guess, the Sketchup time configuration is a bit too "quick" with it's timeline... - violet skys happen when you set midnight
Though, I actually like the sky never saw this time in indigo before so I thought it'd be a pretty uniform exr or something....
