High poly test
Post by CTZn » Fri May 09, 2008 3:35 am
Maybe you could lower max depth in this case, to shorten iterations... A dimmer gray would do anyway, even 50% under sun light. Impressive demonstration !
dougal2
Post by dougal2 » Fri May 09, 2008 5:07 am
You don't need to load the larg meshes into blender - create a dummy object yourself that will represent the large mesh, then:
1. export
2. edit the .igs by hand
3. render
if you notice the centering is off, then you'll have to adjust the center of your dummy object and do steps 1 - 3 again.
Post by fused » Fri May 09, 2008 6:57 am
hafunui wrote:Woah, what kind of render farm does he have. I guess it's worth a try :) But not with those scans; I haven't been able to get indigo to load one of those yet. (i need 64bit probably)
Just a P4 3.2ghz an 1gb ram, rendered for ~12h :)
dougal2 wrote:You don't need to load the larg meshes into blender - create a dummy object yourself that will represent the large mesh, then:
1. export
3. render
Cindigo has such a dummy object integrated, where you can specify the path to an external object, the bounding box size and the center (wich will be drawn in the editor), maybe its wort implementing sth in blendigo/mti/maxigo?
dougal2
Post by dougal2 » Fri May 09, 2008 7:55 am
Could be done fairly easy with a custom locator for MtI, but currently no support for "external" objects, although instancing of real objects is there.
hafunui
Post by hafunui » Fri May 09, 2008 8:14 am
Then it's probably my materials making it slow.
Post by fused » Fri May 09, 2008 8:36 am
try using a sun with pathtracing, that speeds it up a lot.
Post by CTZn » Fri May 09, 2008 10:54 am
How do you set path tracing ? Is that when MLT, Hybrid and Bidir are off ?
Maya has a reference system wich allows to have geometries offline, but you need to load the mesh once anyway I think. That allows to modify single object without editing the main scene. External meshes in MtI could be as easy as setting a full path instead of a mesh name into instancing locators, as Doug said.
alexmeyer
Post by alexmeyer » Fri May 09, 2008 10:55 am
Yes, though I think BiDir can be on. That just affects how the path tracing/MLT works.
MLT on/off chooses between path tracing and MLT.
Hybrid on/off chooses between (path/MLT, whatever you chose) and a path/MLT mixture.
Bidir on/off just changes the behavior of the above-mentioned modes.
Post by CTZn » Fri May 09, 2008 11:00 am
Thank you ! See, I had fixed this locally long time ago but since, MtI is always forcing MLT on, whatever the checkbox state could be... I was sure we were missing something there !
dougal2
Post by dougal2 » Fri May 09, 2008 11:37 am
Missed that one!
hafunui
Post by hafunui » Fri May 09, 2008 4:36 pm
Well, turns out I CAN load the xyzrgb dragon.
Heres another one that I put together quickly, nothing fancy, just to prove I could do it :D . 26,562 dragons, and 191.7 Billion polygons. My Blender cannot handle any more. It almost took longer to export than it did to render.
They look like crop circles
alexmeyer
Post by alexmeyer » Fri May 09, 2008 4:38 pm
Dude..... that's sick.
Awesome render. :D
Post by CTZn » Fri May 09, 2008 5:00 pm
Totally insane.... World record or ?
Post by Kram1032 » Sat May 10, 2008 10:11 pm
:shock: that's.... :shock:
no words..... :shock:
beta
Post by beta » Sat May 10, 2008 11:42 pm
wooooow! :shock: :shock: :shock: :shock:
i need some tips on instancing cause i don't actually know how to do it... and didn't find any tutorials or anything... and i dont think alt+d is the best way :lol:
any tips?
Users browsing this forum: Semrush [Bot] and 3 guests
