dakiru
Post by dakiru » Sat Mar 30, 2013 12:25 am
Headroom wrote:Little byproduct for a next LED lighting project. Not quite 100% accurate (yet) but good enough for some lighting simulations and the SIMPLE Renderings Thread :wink: .
Cool tech stuff. Can't wait for those "SIMPLE" simulation renders 8)
tarikb
Post by tarikb » Sat Mar 30, 2013 4:06 am
Sketchup ( file size 140mb) :)
3ds models
Archicad export - 3dmax export
20h
Network rendering 3 pc-s
core2duo, nvidia 1024mb, amd crosfire 2x512mb
Skindigo
cotty
Post by cotty » Sun Mar 31, 2013 8:34 pm
A retro microphone...
Post by Zom-B » Mon Apr 01, 2013 5:16 am
cotty wrote:A retro microphone...
A gigantic one if you think about the size of the floor tiles :P
cotty
Post by cotty » Mon Apr 01, 2013 8:17 am
"Adlerauge sei wachsam"
Yes, you are right, I hoped that no one will notice it 8)
OR: I used a special bonsai wood for the floor tiles :lol:
Post by Zom-B » Mon Apr 01, 2013 9:38 am
cotty wrote:OR: I used a special bonsai wood for the floor tiles :lol:
Thats what I'll ask in such a case from now on, awesome :D
Rezca
Post by Rezca » Mon Apr 01, 2013 4:45 pm
Um.. Nothing real fancy here, just an interior with a snake in it :3
I can never seem to do any sort of interior render without some reptile in the image. :lol:
It's my friend's royal/ball python "Julius Squeasar" ^^ (Using a photo of his snake as my avatar)
Though the texture is more like a Burmese texture, but I don't have any royal python textures.
22 hours and 30 minutes rendering, and next sampling update expected in another 22 hours? *huffs* I really wish I could have my desktop working on this instead of my laptop but I've only got one license!
Indigo RT, and only a single Sunlight. Aperture Diffraction enabled, which was in hindsight probably unneeded and a bad idea :lol:
Hm.... Would adding a second light to the scene help grain clear up faster? I've never really had any luck with multiple lights in a sunlit scene. No matter what intensity or light type I set the other lights to, they never show up *shrugs*
Oh well, still learning I am =)
Cinema 4D R13 Visualize + Indigo Render
Post by Oscar J » Mon Apr 01, 2013 11:14 pm
What render mode are you using? Try BiDir with exit portals, it should be much faster. I like your scene, although the table looks a little over-saturated, and the snake could use some kind of bump map.
Rezca
Post by Rezca » Tue Apr 02, 2013 12:19 am
Oscar J wrote:What render mode are you using? Try BiDir with exit portals, it should be much faster. I like your scene, although the table looks a little over-saturated, and the snake could use some kind of bump map.
For that image it was Pathtracing with BiDir.
The snake is using a bump map, and in an earlier render of mine that was dimly lit it showed up... But I was using a different diffuse texture then. ^^ It's harder to see the bump on this one. I upped it from 0.013 to 0.023 for the next render.
I also added in the Exit Portals and changed to MLT with BiDir to see what happens.
As for the table... I dunno. I guess I could change the texture, or reduce the saturation a bit... The texture I was using was quite saturated to begin with.
I'll attach an image once I let it render for a bit. Thanks for the feedback ^_^
*edit* Well here it is with light portals and MLT BiDir rendering.
I can't see the fence I had outside the window anymore though. I lost the camera I was using before so had to pick a new angle. Added a plant with the new Two-Sided Thin material, and adjusted the snake's pose a bit (His tail was intersecting with the couch in the background before). Also reduced the saturation on the wood material by 10%
45 minutes of rendering time.
*edit 2* Second image is the result of five hours of rendering.
Finished product.
Post by Zom-B » Tue Apr 02, 2013 11:51 pm
Nice image and concept Rezca :)
But your Snake would defenetly be happy about some bump, normal or displacement map! Exponent map and/or fresnel skale map would help to to give the scales a more natural look ;)
Rezca wrote:I can't see the fence I had outside the window anymore though.
Meshes behind ExitPortals don't get rendered anymore!
Rezca
Post by Rezca » Wed Apr 03, 2013 4:31 am
Zom-B wrote:Nice image and concept Rezca :)
Thanks ^^
I disabled the color and rendered it for a while and the bump really isn't showing up very well at all. I thought it was the texture at first, since I had gotten a nice bump to show up with the bumpmap I'm using in a different render... Hm.
I'll have to look into that, though I wouldn't know the best way to go about making one ^^
Ah yes, only a few hours after I started rendering I read about that.
Also two more simple renders~
One I was in the mood for glowy things in a dark room, the other was an attempt at caustics.
23 minutes rendering and seven hours rendering. Technically I felt it had cleared up enough at one hour, but I let it continue polishing away while I went to bed.
First scene is definitely simple! One plane object, some extruded primitive objects with a blackbody emission texture on the inside, and some splines in a sweep object. Simple! :D But I had fun making it.
Attempt at caustics
Attempt at glowing things. I love glowing materials in Indigo
tarikb
Post by tarikb » Fri Apr 05, 2013 12:27 pm
Bedroom :)
Skindigo
Rezca
Post by Rezca » Sun Apr 07, 2013 12:15 am
Simplicity itself ^^
Post by Zom-B » Sun Apr 07, 2013 12:21 am
Rezca wrote:Simplicity itself ^^
Sweet atmosphere in that image.
Some more work on the materials and that can become quite a beauty :)#
P.S. voting for some ugly aliens floating in the tanks instead of palmtrees :D
Post by CTZn » Sun Apr 07, 2013 1:17 am
nicecity ?
