Page 1 of 3
Loft
Posted: Thu Mar 22, 2007 9:09 pm
by 8bstudio
Hi to all!
I post another work wip of interior architecture. It's a loft!
Indigo 0.7t5, 12 hours, only .exr -
Next image I try skylight.
Posted: Thu Mar 22, 2007 9:25 pm
by BbB
Really nice. How exactly did you model the steps? And what exr are you using here?
Posted: Thu Mar 22, 2007 9:39 pm
by 8bstudio
Thanks BbB!
The steps are mapped with alpha map environement for the holes and .exr is a simple sunny day!
Posted: Thu Mar 22, 2007 9:42 pm
by BbB
Actually never used alpha maps. Think you could post your map? Looks very convincing...
Posted: Thu Mar 22, 2007 9:51 pm
by 8bstudio
Posted: Thu Mar 22, 2007 10:01 pm
by BbB
Ok, but how do you use it? And with which exporter? Is this a blend material?
Posted: Thu Mar 22, 2007 10:03 pm
by BbB
Posted: Thu Mar 22, 2007 10:36 pm
by 8bstudio
I use BlenderIndigo (by Zuegs) and material is blend material.
Here the code:
<material>
<name>lamierino</name>
<blend>
<a_name>acciaio</a_name>
<b_name>null</b_name>
<blend_factor>0.5</blend_factor>
<blend_map>
<path>testscenes\foratura.jpg</path>
<uv_set>uv</uv_set>
<exponent>1.000000</exponent>
<a>0</a>
<b>1</b>
<c>0</c>
</blend_map>
</blend>
</material>
Posted: Thu Mar 22, 2007 10:39 pm
by BbB
Thanks a lot, sorry for being such a noob
Posted: Fri Mar 23, 2007 12:52 am
by Stur
Don't be sorry as it helps other noobs
Thx 8bstudio, and nice picture !
Posted: Fri Mar 23, 2007 1:01 am
by manitwo
good start 8bstudio!
your stairs need a few struttings (dont know if this is the right word).
The stair construction, as it is now, would succumb.
and your glass walls look very thin.
btw: nice to see your old wine bottle again
Posted: Fri Mar 23, 2007 1:13 am
by mrCarnivore
I like the render but I second manitwo's criticism.
The wine bottle and the glass look out of place there and instantly give the image away as a render... I would get rid of them. If you really like them. Put them into the dining room on a table, but I wouldn't even do that.
Posted: Fri Mar 23, 2007 2:56 am
by 8bstudio
manitwo wrote:good start 8bstudio!
Thanks for yours comments!
Strange because stair is mathematic calculed: is piercing plate thin 5mm... I'll control that again! Glass is 10mm.
This image is for client who wants choose color of floor and light.
Next image shall with table!
Posted: Fri Mar 23, 2007 2:57 am
by 8bstudio
Glass is 10mm. and needs still some structure
This image is for client who wants choose color of floor and light, next image shall with table!
Posted: Fri Mar 23, 2007 10:10 pm
by 8bstudio
Hey guys!!
Here two last versions:
Next with sun sky!!
