8bstudio
by 8bstudio » Thu Mar 22, 2007 9:09 pm
Hi to all!
I post another work wip of interior architecture. It's a loft!
Indigo 0.7t5, 12 hours, only .exr -
Next image I try skylight.
by BbB » Thu Mar 22, 2007 9:25 pm
Really nice. How exactly did you model the steps? And what exr are you using here?
8bstudio
by 8bstudio » Thu Mar 22, 2007 9:39 pm
Thanks BbB!
The steps are mapped with alpha map environement for the holes and .exr is a simple sunny day!
by BbB » Thu Mar 22, 2007 9:42 pm
Actually never used alpha maps. Think you could post your map? Looks very convincing...
by BbB » Thu Mar 22, 2007 10:01 pm
Ok, but how do you use it? And with which exporter? Is this a blend material?
by BbB » Thu Mar 22, 2007 10:03 pm
8bstudio
by 8bstudio » Thu Mar 22, 2007 10:36 pm
I use BlenderIndigo (by Zuegs) and material is blend material.
Here the code:
<material>
<name>lamierino</name>
<blend>
<a_name>acciaio</a_name>
<b_name>null</b_name>
<blend_factor>0.5</blend_factor>
<blend_map>
<path>testscenes\foratura.jpg</path>
<uv_set>uv</uv_set>
<exponent>1.000000</exponent>
<a>0</a>
<b>1</b>
<c>0</c>
</blend_map>
</blend>
</material>
by BbB » Thu Mar 22, 2007 10:39 pm
Thanks a lot, sorry for being such a noob
Stur
by Stur » Fri Mar 23, 2007 12:52 am
Don't be sorry as it helps other noobs
Thx 8bstudio, and nice picture !
manitwo
by manitwo » Fri Mar 23, 2007 1:01 am
good start 8bstudio!
your stairs need a few struttings (dont know if this is the right word).
The stair construction, as it is now, would succumb.
and your glass walls look very thin.
btw: nice to see your old wine bottle again
mrCarnivore
by mrCarnivore » Fri Mar 23, 2007 1:13 am
I like the render but I second manitwo's criticism.
The wine bottle and the glass look out of place there and instantly give the image away as a render... I would get rid of them. If you really like them. Put them into the dining room on a table, but I wouldn't even do that.
8bstudio
by 8bstudio » Fri Mar 23, 2007 2:56 am
manitwo wrote:good start 8bstudio!
Thanks for yours comments!
Strange because stair is mathematic calculed: is piercing plate thin 5mm... I'll control that again! Glass is 10mm.
This image is for client who wants choose color of floor and light.
Next image shall with table!
8bstudio
by 8bstudio » Fri Mar 23, 2007 2:57 am
Glass is 10mm. and needs still some structure
This image is for client who wants choose color of floor and light, next image shall with table!
8bstudio
by 8bstudio » Fri Mar 23, 2007 10:10 pm
Hey guys!!
Here two last versions:
Next with sun sky!!
Users browsing this forum: No registered users and 130 guests
