LEGO render
11 posts • Page 1 of 1
contegufo
LEGO render
Post by contegufo » Thu Apr 14, 2016 11:31 pm
Hi
The pins are of brick faceted you can have them smooth?
In C4D function Mesh / Subdivide not results. In SketchUp I do not know.
Rendering in SketchUp.
Stinkie
Re: LEGO render
Post by Stinkie » Fri Apr 15, 2016 6:51 am
They simply need more segments. :)
vasco
Re: LEGO render
Post by vasco » Fri Apr 15, 2016 6:58 am
Hi contegufo,
in german the function is called -Kanten abmildern-, select the mesh(edges+faces) you wand to smooth->right click-> smooth edges, or something like that.
yonosoy
Re: LEGO render
Post by yonosoy » Fri Apr 15, 2016 9:54 am
Hi contegufo.
Try to add a phong tag, seems that the mesh has not one.
"... the hamster don't see the wheel, and this wasn't said before." (yoS eidaN "el Olvidao")
https://www.instagram.com/yonosoy_nada/
contegufo
Re: LEGO render
Post by contegufo » Fri Apr 15, 2016 11:53 am
Hi
After you apply the tag to all objects Phong OpenGL preview is correct and also rendering in Indigo.
However, enlarging the area you can still see the faces.
Re: LEGO render
Post by pixie » Fri Apr 15, 2016 8:45 pm
contegufo wrote:Hi
It doesn't do magic, it works with what it have. The phong is applied you have to make a cylinder with more faces.
DanJ
Re: LEGO render
Post by DanJ » Fri Apr 15, 2016 9:14 pm
In SketchUp, when you first draw the circle before using the Push/Pull Tool, select the circle, right click, Entity Info then change the number of segments to a higher number, for example 96 rather than the default of 24.
contegufo
Re: LEGO render
Post by contegufo » Fri Apr 15, 2016 9:46 pm
Hi
Unfortunately there are too many to be redone, and it makes no sense. I will not make enlargements but only shots That do not see the facets.
Or I will cover the bricks so everything remains hidden.
The bricks are imported from LeoCAD.
Re: LEGO render
Post by pixie » Fri Apr 15, 2016 9:58 pm
contegufo
Re: LEGO render
Post by contegufo » Fri Apr 15, 2016 11:18 pm
Hi pixie
Thanks, Brick gen plugin cost €9.
It seems very versatile and solves the problem by increasing the number of the faces.
Re: LEGO render
Post by pixie » Sat Apr 16, 2016 1:58 am
contegufo wrote:Hi pixie
This was not the lego Plugin I was looking for, sorry! xD
https://cgtools.com/lego4d/
This is, and also free
Users browsing this forum: Semrush [Bot] and 5 guests
