Material that imits Vray's Toon effect.
bahamut : YO. Guys.
bahamut : i have a problem. Is there any possibility to have in indigo something like outlined edges?
bahamut : like with vray toon?
bahamut : I need to do some quasi technical animations and they would like tho have it that way
Ono-Sendai : hmm
Ono-Sendai : yeah probably
Ono-Sendai : with albedo shader on diffuse using cos theta stuff
Ono-Sendai : will try that later
bahamut : Please do
bahamut : I don't want to buy vray for this
Ono-Sendai :
Ono-Sendai : can u make a forum thread for it?
Ono-Sendai : will post my material in there
Done
Ono-Sendai : hmm
bahamut : Please do
Ono-Sendai :
Done
Re: Material that imits Vray's Toon effect.
Luminance slot?
I was thinking about those: https://flyingarchitecture.com/forum/data/forum/618.jpg
Black lines. The rest should remain normal
Here's an attempt.
- cartoon_shader.igm
- (443 Bytes) Downloaded 413 times
Looks very promissing
UNfortunately i got this message: A problem occurred with the scene:
Error while building scene: Error while loading diffuse material 'mat1': Invalid character '?'.
buffer, line 6:
vec3(line ? 0.1 : 0.6)
What version of idigo should I be using?
buffer, line 6:
del
sorry for my ignorance, Ono, but can you explain the || bit of the code within "line"? seems like an "and" or "also" type operation? this effect is similar to somethings I have been trying to work out on my own, combining meanCurvature() with some other property, but I think my approach has been super convoluted so far. I'd like to understand this more...
|| is logical or.
ok, roughly what I suspected, but somehow couldn't find info on it anywhere. thanks!
- pixie
isl potential is humongous!OnoSendai wrote:Here's an attempt.
To me it seems not work.
The shader is working but it is not fit for your scene, contegufo. It works best with smooth surfaces. Subdividing geometries may produce better results too.
- pixie
And the should have a little bevel too.CTZn wrote:The shader is working but it is not fit for your scene, contegufo. It works best with smooth surfaces. Subdividing geometries may produce better results too.
Users browsing this forum: No registered users and 99 guests
