Thank you Soup
1 question when uploading materials to MDB,
is it ok if i give full link to where material properties is based on,
or but because of spam probably better would be to edit like:
from
http://refractiveindex.info/
http://minerals.gps.caltech.edu/FILES/V ... tz/rose.mt
to
refractiveindex info
minerals gps caltech edu FILES Visible quartz rose mt
The material is glossy transparent with absorption layer transmittance texture and subsurface scattering.
Anyway i had diffuse transmission data, not 100% sure if i calculated absorption right (visually it looked ok)
2nt column from:
would be X
and absorption = LOG(1/(1-X))
And Because measured sample thickness wasn't given
i take from http://minerals.gps.caltech.edu/FILES/V ... z/rose.gif
@ 500 nm abs = 0,636
but my calculated abs @ 500 nm from data file = 0,4153536
=> 0,636/0,4153536*Absorption*100
But i like more lighter Rose Quartz so i divide abs values
Gemstones
Re: Gemstones
You can go ahead and post those links in the material's pageMeelis wrote:Thank you Soup
from
to
Re: Gemstones
26 materials that use measured data.
Rose Quartz scattering down to 400 to spice it up a bit.
Re: Gemstones
WOW your renders are soo beautifuldag wrote:26 materials that use measured data.
I must say some of the materials i made look very different from some gemstones that were in MDB before i uploaded some of theme there. The default previews looked very same for example Emerald's, Topaz's, Amethyst's. Your preview gives much better overview i must say especially for the really dark gemstones. On default preview Italy Andradite and Brazil Greenish-yellow Chrysoberyl looked like the same.
I haven't uploaded some black looking on preview scene, allthow on photos they look nice,
the very dark like: Thailand Ruby, Afghanistan Dark Green tourmaline, USA Georga lazulite, Island Blue Cobaltian Spinel.
But the dark gems look really good in small size
Like on that photo:
Re: Gemstones
That's a nice material reference How big are these gems?dag wrote:26 materials that use measured data.
Re: Gemstones
1cm diameter (4 carat) on the diamond cut.
Most of these would probably look better on different cut gems, but was too lazy to model different ones.
Re: Gemstones
Thanks! Actually, you don't have to model themdag wrote:1cm diameter (4 carat) on the diamond cut.
