Need Help, A weird line shows up when using SSS mat.
5 posts • Page 1 of 1
butaixianran
Post by butaixianran » Sat Nov 10, 2018 10:38 pm
I'm using Fast Skin mat from indigo mat lib to a body. But a weird line shows up at the edge of mat.
This line only shows up when SSS is used.
How should I fix it? Thanks.
yonosoy
Re: Need Help, A weird line shows up when using SSS mat.
Post by yonosoy » Sun Nov 11, 2018 5:07 am
Try to name all the mediums involved in the body with the same name (only the mediums, not the material). Maybe you need to use external reference materials for this.
It is a little bug, but this works fine for the moment.
"... the hamster don't see the wheel, and this wasn't said before." (yoS eidaN "el Olvidao")
butaixianran
Post by butaixianran » Sun Nov 11, 2018 11:25 am
Changing internal medium's name truly fixed this problem, thanks!
What a weird bug.
Post by fused » Wed Nov 14, 2018 12:27 am
You can also use the "share medium" option in c4d. This way you can make sure all materials use the same medium.
Post by zeitmeister » Wed Nov 14, 2018 7:53 am
That’s how it goes! :-)
