Help me render my scene
I have a PC, Intel Pentium III, only 128 MB SDRAM
Rendering a simple scene needs 24 hours or more
Can somebody help me?
Render my scene...
Render my scene...
yes ahmadun: post your scene wherever you prefer (i find www.box.net useful and easy-to-use ). And, yes: specify your modeling application!!
- Kosmokrator
even an biased renderer man.....zsouthboy wrote:Ouch, that's a box that'll be painful to use any unbiased renderer on.
If you would post the scene, I'm sure one of us would be happy to render it on an idle box for you.
btw i have make some interesting 3d on biased 3d app in the past with an machine like this...
3ds max 2 default scanline.....aahhh times to remember ....
Try this...
OK, thanks a lot.
Now try this...
Now try this...
- simple.igs
- (1.16 MiB) Downloaded 275 times
Hi ahmadun,
I'm rendering your scene now - but WOW is it slow for such a simple scene. (Which isn't helping your poor processor try to deal with it)
A quick glance shows two SSS materials, not just SSS, but RGB SSS, which is even slower!
Change your scattering to uniform (this looks like it was exported from Blender, correct?)
I can't visualize where your light in this scene is, either - and switching to PT (which would quickly show any direct light) shows barely anything! So your entire scene is being lit with indirect light (as I only see anything when turning MLT on), THEN going through SSS mediums, before getting to the camera.
Can you show me a wireframe of your scene (again, I'm postulating that you're using Blender) or perhaps the .blend itself?
- Here's the render at about 2000 samples per pixel
- im1214142712.png (183.8 KiB) Viewed 4710 times
- Borgleader
- Borgleader
- Borgleader
Hahaha ok. Well I'm stopping too, cuz well its inefficient, and I cant play Age of Conan now (I didnt mind doing it while i was at work cuz ...my computer would've just been idle anyway).zsouthboy wrote:Haha, you win - I stopped rendering it when I posted, since it's so inefficient.
- Here's the latest.
- im1214149250.png (180.53 KiB) Viewed 4681 times
- joegiampaoli
... compliments of the RANCH ...
Render time charged: 00 h 22 mn 20 s.
Volume of data to download: 78.21 MB (original .vui file not included).
Maximum RAM usage while rendering: 132.48 MB.
Samples Per Pixel (SPP) reached: 25962.
Volume of data merged to produce the final IGI: 8.09 GB
... very different results than the others ...
- simple_final.png (1.69 MiB) Viewed 4671 times
- Borgleader
Actually the RANCH igi merging Software had some bug,
they weighted incorrectly when merging IGIs!
Should be fixed now...
Also Ono told that SSS is buggy,as he told RGB SSS sampling has severe issues,
the more the scattering coefficients vary based on wavelength,
the worse the noise will be...
my SSS RANCH test were unsatisfying too...
