How to create an object without shadow while cast light
Tutorials/guides/tips on how to use Indigo and the Indigo exporters
6 posts • Page 1 of 1
anonym0214
Post by anonym0214 » Fri Jul 04, 2014 2:20 pm
Hi, Pros,
I am a new user of Indigo.
I have a question:
I want to use a illuminating box to imitate directional light. However, when I render the scene, the box is rendered along with its shadow.
Can I make the box and its shadow missing in the rendered result while the lighting from it remains?
Please help me with it.
Thank you.
Re: How to create an object without shadow while cast light
Post by Zom-B » Fri Jul 04, 2014 10:42 pm
Hey 0214,
anonym0214 wrote:I want to use a illuminating box to imitate directional light.
Please explain (with an image) what you want to achieve here.
Are you referring to use a 360° image for lighting, or using a "studio setup" (Box) to light some object...
bubs
Post by bubs » Sat Jul 05, 2014 2:03 am
If it is just an object within the scene, use 'Pick Object' then check the 'Invisible to Camera' box in the 'Property Editor'
aleksandera
Post by aleksandera » Sat Jul 05, 2014 4:46 am
I think what he wants is a light catcher ;)
anonym0214
Post by anonym0214 » Fri Jul 25, 2014 3:21 pm
Zom-B wrote:Hey 0214,
Hi, Zom-B,
Please check out the attached image. The yellow quad is used for lighting, however, you may see its shadow casting to the floor. How can I remove the shadow while keep the quad emitting light?
Thank you so much.
p.s. I am using the Indigo RT instead of Indigo Renderer. So please tell me to use the feature that I have. Thank you so much. ^_^
anonym0214
Post by anonym0214 » Fri Jul 25, 2014 3:37 pm
Please view the attached image. I want to make the shadow of the yellow square gone. How do I do that?? (I am using Indigo RT)
