Using render foreground alpha in skindigo
Is there any special way to enable it in 1.1.6?
Re: Using render foreground alpha in skindigo
advanced->tracing method->alpha render
The background is completely black and anything in my scene turns completely white..
yes...what's the problem?neo0. wrote:??
Uhm, I assumed it was pretty clear in my request, but I was looking for something to render a transparent background and still leave me with a usable render in the process. Whats the point of turning everything white?
LOL. the way it works now is by creating a mask which you can use in your favorite image editor to remove the background from your render.
- Borgleader
That is so cool I'll have to check if blendigo has it if not request it. im glad i come over here XDcpfresh wrote:LOL. the way it works now is by creating a mask which you can use in your favorite image editor to remove the background from your render.
I dont think indigo has a no background option does it? im just asking out of curiosity because i like the mast solution better, just because you could tweak the mask in photoshop and so you have more flexibility than a straight transparent .png
Oh gee, McGyver.. What about your actual scene..? What possible purpose does turning it all white serve? Are you supposed to remove that part with an image editor too?
- Borgleader
He just said it....A mask in photoshop uses the grayscale value of the image pixels to determine the transparency of another layer. Black = Transparent, White = Opaque.
Your scene = white, therefore it will still be visible with the mask applied
The background = black, therefore transparent with a mask
lrn2google.
lrn2google.
Uhm, when was the last time you saw a great render that was made out of white objects?
What would have been wrong with rendering to a gif file or another format that supports alpha?
- Borgleader
Read my post again...this option will create a MASK which you apply on your normal render to take out the background. Like I said the background part on the mask will be black and so with the mask on the render it will become transparent, however your scene will remain untouched.neo0. wrote:Uhm, when was the last time you saw a great render that was made out of white objects?
Neo0: as a reference for an alpha render.
- It is from blender but it reveals what an alpha render is. What's not covered by an object (even if transparent) turns white.
- reveal_alpha_mask.jpg (66.35 KiB) Viewed 7570 times
Very strange to read such thread in 3D forum.
neo0. wrote:??
You're in college, neo?
I'm 14 and I'm laughing at your ignorance.
samlavoie.xyz
