by neo0. » Wed Jan 28, 2009 4:15 pm
Sorry, I mean like if you use a blend mat to create etched glass or.. Well.. Hold on
- im1233114406.png (485.61 KiB) Viewed 2689 times
naopachke
by naopachke » Sat Feb 07, 2009 9:45 am
does anyone know what the hell is this? and how to correct it?
I'm using skindigo .15 with indigo .15 - and after a correct instalation this appeares when I click on skindigo..
also: no skindigo icons appear on sketchup toolbar?!
- untitled.JPG (65.99 KiB) Viewed 2582 times
crojack
by crojack » Sat Feb 07, 2009 9:59 am
make sure that your internet explorer isn't blocking scripts from running
naopachke
by naopachke » Sun Feb 08, 2009 1:03 am
i've tried messing around IE settings and no results.. can you be more specific? i have XP and IE7 (but I use firefox)
crojack
by crojack » Sun Feb 08, 2009 6:14 pm
All the windows for Skindigo are basically IE html windows so sometimes if IE is blocking javascript it can block Skindigo from working. But, which specific settingss to looks for, other than not allowing javascript, I'm not sure.
naopachke
by naopachke » Tue Feb 10, 2009 3:01 pm
I'm going insane here.. I've done all I can think of to IE settings (enabled running scripts from local machine..) - and when I launch skindigo's settings.html directly into IE, it doesn't show any more errors or blocking java and runs nicely, but when I open sketchup and start indigo settings form there, it just won't work. same with skindigo 1.1.12... btw skindigo's render works normaly, so it's definently a java error.
kellpossible
by kellpossible » Tue Feb 10, 2009 5:33 pm
I'm sure whaat would be able to help you the most, seeing as he is the one who made the exporter window... Maybe there is some error with the way you have it configured?
by Whaat » Wed Feb 11, 2009 3:38 am
In Internete Explorer, try Tools->Internet Options->Advanced->Reset..
naopachke
by naopachke » Wed Feb 11, 2009 10:22 am
got it!
first nothing, but after a system restart, all is ok. I'm still a bit puzzled, but who cares when it works. Thanks whaat; thanks guys for your help.
xrok1
by xrok1 » Wed Feb 11, 2009 11:40 am
Whaat, please check out this post
http://asgvis.com/smf/index.php?action=search2
it seems to be happening again with the latest version of skindigo and vray?
i know its pointless to notify AGVIS but i will anyway, i'm hoping you can fix on your end.
BTW besides the annoyance of the message popping up its still seems to function fine.
- Capture.JPG (27.74 KiB) Viewed 2410 times
