by neo0. » Sat Oct 25, 2008 3:50 pm
Hi, so you may remember my scene with the observation room. What I did was stick a big plat piec eof geometry and map an image of a planet to it. Wasn't the best idea..
So any how, does skindigo export the background image too?
by neo0. » Mon Oct 27, 2008 3:39 pm
Doesn't anyone know what im talking about? Background image? You click on window then style.
by Whaat » Mon Oct 27, 2008 4:58 pm
You talking about watermarks? SkIndigo does not export watermark images.
by neo0. » Mon Oct 27, 2008 5:18 pm
Could it in the future. It would be great imo.
ZYX
by ZYX » Sun Nov 02, 2008 7:02 am
neo0. wrote: Hi, so you may remember my scene with the observation room. What I did was stick a big plat piec eof geometry and map an image of a planet to it. Wasn't the best idea..
If you want to render a background image without using an environment map just put as a plane with the image you want to render set as a RGB emmiter and adjust the power/efficacy until it looks ok.
by neo0. » Sun Nov 02, 2008 6:47 pm
Out of curiosity how hard would background images/watermarks be to implement.
by Whaat » Mon Nov 03, 2008 3:39 am
neo0. wrote:Out of curiosity how hard would background images/watermarks be to implement.
Not hard...impossible. The SketchUp API does not allow access to watermarks/background images. Hopefully, this will be changed when SU7 is released.
by neo0. » Thu Nov 06, 2008 12:43 pm
IS it possible to render with a alpha channel?
by neo0. » Sun Nov 16, 2008 10:46 am
Okay, I went with ZYXs suggestion and Im getting some pretty decent results.
The floor texture was originally green. Is there any way, I can prevent so much light from flooding into the room?
- im1226787902.png (1.15 MiB) Viewed 2685 times
by neo0. » Sun Nov 16, 2008 11:40 am
Uh, and now it refuses to display anything sans backness.. This makes no sense at all..
ZYX
by ZYX » Tue Nov 18, 2008 2:49 pm
neo0. wrote:Okay, I went with ZYXs suggestion and Im getting some pretty decent results.
Reduce the power of your main emitter or/and change the tonemapping of your scene and see what happens.
delle
by delle » Wed Nov 19, 2008 6:02 am
Hi, I have the same problem (even if I'm not using Sketchup)
I'd like to add a background image (e.g. a City) without adding a "fake plane" that will block the Sun.
Is it possible (in Indigo) to save an alpha plane (32 bit PNG) in order to add the City image via post-processing (e.g. Photoshop) ?
Thank you.
Delle
- im1227017515.png (924.65 KiB) Viewed 2590 times
by Kram1032 » Fri Nov 21, 2008 10:17 am
via Photoshop or Gimp, you can extract the Alpha-channel and use it as an alpha map in Indigo, if that's what you meant... (at least, if the alpha map isn't somehow written into the R, G and B channel...)
by neo0. » Fri Nov 21, 2008 8:30 pm
Does skindigo support alpha mapping?
Users browsing this forum: No registered users and 57 guests
