Some questions
Some questions
I gathered glass needs to have a thickness. A window, in essence, needs to be a box, and the white faces need to point outwards.
But, there's a 'thin glass' preset in the exporter. Am I right in thinking that this can be used to apply 'glass' to a single pane? And if so, how should the white side be pointed (I'm guessing: towards the viewer)?
Last but not least: exit portals. Pretty cool, but how are they used exactly? This is my understanding: make a window opening, put some glass in it. Then put an exit portal in the window opening, parallel to the glass, same size as the glass. Something like this?
Re: Some questions
YesStinkie wrote: But, there's a 'thin glass' preset in the exporter. Am I right in thinking that this can be used to apply 'glass' to a single pane?
orientation doesn't matter for Thin GlassAnd if so, how should the white side be pointed (I'm guessing: towards the viewer)?
Avoid using the glass unless you must have reflections. If using glass, the exit portal should be at least 1-2mm outside of the glass. The exit portal can be bigger than the glass. It can even be a big box or plane covering multiple window openings (AFAIK).Last but not least: exit portals. Pretty cool, but how are they used exactly? This is my understanding: make a window opening, put some glass in it. Then put an exit portal in the window opening, parallel to the glass, same size as the glass. Something like this?
Sry, no, I didn't say it clear.
The geometry behind it wont show up! Everything behind the portal is invisible, except the absolute background (Sky, Exr, etc)
The portal should be as close to the window as possible, but a minimum distance of 1mm is recommended the glass should be between the camera and the portal
if i understand them correctly, exit portals are intended to reduce render times by making the render engine only process light which passes through the portal. this way light which never makes it through the window and into the scene is never even considered by the engine so no processing power is wasted ...
result: faster convergence.
I suppose they would be equivalent to a Roughness Map in Maxwell or Fryrender. The IOR of the material is not affected by the exponent map. However, the glossiness of the reflection is.Stinkie wrote:Here I am again. Going thru Whaat's tuts. Very informative stuff. Yet: another question.
Here goes: exponent maps, are those the same thing as specular maps?
Look at this thread:
http://www.indigorenderer.com/joomla/fo ... 85&start=0
Users browsing this forum: No registered users and 121 guests
