material import problem
2 posts • Page 1 of 1
cotty
Post by cotty » Mon Sep 05, 2016 6:26 am
I get this ruby error message every time I import a material from the database:
"SketchUp:1:in `call'
Error: #<Exception: no model for material>
C:/Users/cotty/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/skindigo/IndigoMaterial.rb:492:in `texture='
C:/Users/cotty/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/skindigo/indigoMatImport.rb:1154:in `load_bc_textures'
C:/Users/cotty/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/skindigo/indigoMatImport.rb:888:in `block in load_igm'
C:/Users/cotty/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/skindigo/indigoMatImport.rb:764:in `each'
C:/Users/cotty/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/skindigo/indigoMatImport.rb:764:in `load_igm'
C:/Users/cotty/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/skindigo/SkindigoMatObserver.rb:204:in `block (2 levels) in initialize'
SketchUp:1:in `call'"
(Indigo 3.8.34 64-bit)
devrim
Re: material import problem
Post by devrim » Fri Oct 28, 2016 4:50 am
Hi;
I have similiar problem. When I try to download any material from material database I get thıs message;
Error: Failed adding the material to the local database: Failed to parse material: Failed to find expected element 'diffuse_albedo_spectrum'. (In element 'scenedata / material / phong'): <phong> <diffuse_albedo> <texture> <path>tiled_wood02_diffuse.jpg</path> ...
You can see the attached file.
As far as I understand It is because of new version of İndigo .
Hope somebody can sort out the issue.
Regards...
V3.8.31-64 bit
