Scattering during animation
3 posts • Page 1 of 1
ak-sam
Post by ak-sam » Mon Jan 11, 2016 9:18 am
Hi folks
I'm finally getting around to animating some fly-throughs ...so far so good, except the vegetation I have scattered using the Scatters Editor is re-generating each frame using a different seed.
My seed is set to 0 in indigo - should it be set to something else?
Cheers
STUDIO AARON
Re: Scattering during animation
Post by STUDIO AARON » Sat Jan 16, 2016 7:29 am
Hi
My "scatter seed" is usually set at 1 and works for fly-through animations. (Render Que shows seed at 0)
See if you have "Only in camera view" checked.
This will rescatter for each new camera angle for each frame.
If it isn't checked, skindigo should reuse the first scatter locations for all the frames.
Hope that helps.
STUDIO AARON
Home Design, Rendering, Animation, and Virtual Reality
ak-sam
Post by ak-sam » Mon Jan 18, 2016 9:30 am
Yes that was it - the "Render Only In View" will choose to render the items in direct line of sight of the camera.
In scattering, I guess it's the "seed" that defines whether the object is visible or not.
I had a scene where the camera was moving past a picket fence. The vegetation (shrubs) were appearing to 'flicker' (become visible or invisible) depending on whether it was behind a picket at that moment, or not.
Seems to be fixed now - thanks!
I will post the results if I can get a clean render output sometime soon.
