Tricky mapping
Tricky mapping
Hi to all SketchUp users!
As many of you may know, I might know something about Indigo BUT as a matter of fact I'm NO texturing expert!
So, I have been attracted by this little image and downloaded the model (which I am attaching to this post).
I remembered that someone uploaded a very cool Indigo material based on a bumpy shader which replicates about the same appearance. Well, I tried to map the hell of an object since three days, using all the plugins I know, and I cannot get through this!
Can anybody give me a hint? Pretty pleeeease?
Thanks in advance
Thanks in advance
- horn.zip
- (1.34 MiB) Downloaded 260 times
Re: Tricky mapping
You sketchup users are so spoilt with everything being simple!
Blender is well known for its UV-mapping capabilities. Here's a very basic way to UV map your horn:
https://www.youtube.com/watch?v=ywGA9u5Oy2w
I tried to avoid keyboard commands as far as possible. The "U" key is for the UV-mapping tools and the "S" key for scale.
There are some visible seams though, and if you want to learn how to make a more sophisticated UV-mapping I'd be happy to show you.
Re: Tricky mapping
Hi Oscar!
You've been such a candy to show me how it's done in Blender (and YES, you're right: we sketchup users are USED to easiness )
I actually know that there are some even complex methods in other 3d packages, but although I'd want to see this Satan's Horn finally MAPPED no matter how , I'd very like to know if any other SketchUp user could find a way to do it.
I thank you so much for your kindness, btw. This place is filled with beautiful people
Re: Tricky mapping
Pibuz,
I got it pretty good, there's a bit of stretching, but nothing unacceptable I think.
You need to make some seams on your model.
I separated it into 4 elements
1. Outside skin
2. Inside skin
3. Rim of opening
4. Tip on horn
I did this using the 'path select' tool from Whaat's SketchUV plugin
I then used Fredo's 'ThruPaint' plugin on QuadMesh UV setting on each element individually, and moved them about until they lined up a good as possible.
1. Outside skin
2. Inside skin
3. Rim of opening
4. Tip on horn
Re: Tricky mapping
Nice one bubs!
- Polinalkrimizei
Re: Tricky mapping
Cool to find something that seems much easier in Blender than in SketchUp
Re: Tricky mapping
It is a constant pain, and one of my main draws to learn another modelling package... anything other than straight planar UV mapping can be an absolute nightmare with SketchUp...
Re: Tricky mapping
Pibuz, did you have any luck with this mate?
Re: Tricky mapping
Eclat-Digital Research
http://www.eclat-digital.com
Re: Tricky mapping
@ galinette
Hi man, yes I wanted exactly this material. But for it to work I need to correctly map the surface, hence my problem
@ bubs
It's been very kind of you. I'm a total disaster concerning non-planar mapping I know all of the plugins you mentioned but never took my time to learn it. Thanks for pointing out the 'correct' workflow, I'm gonna try that ASAP!
@ bubs
