nosek1995
by nosek1995 » Sun Dec 21, 2014 11:31 pm
It's not working. I installed everything, following the instructions. I have SketchUp 2015. Everytime I open it a thing like that pops out:
Error Loading File C:/Users/Właściciel/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/skindigo/skindigo_core.rb
Error: #<LoadError: No such file or directory -- C:/Users/Właściciel/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/skindigo/SkIndigoUVS.rb>
C:/Users/Właściciel/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/skindigo/skindigo_core.rb:12:in `load'
C:/Users/Właściciel/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/skindigo/skindigo_core.rb:12:in `<top (required)>'
C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in `require'
C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in `load'
C:/Users/Właściciel/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/skindigo.rb:19:in `register_extension'
C:/Users/Właściciel/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/skindigo.rb:19:in `<module:SkIndigo>'
C:/Users/Właściciel/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/skindigo.rb:4:in `<top (required)>'
Help me! Please!
- 3D Software: SketchUp
by Pibuz » Tue Dec 23, 2014 3:18 am
99 over 100% the problems are caused by the non-english characters on the username you use.
by OnoSendai » Tue Dec 23, 2014 3:22 am
Pibuz wrote:99 over 100% the problems are caused by the non-english characters on the username you use.
Unicode support should be working properly in SketchUp 2015 though.
by Pibuz » Tue Dec 23, 2014 3:24 am
..reading from the second line "C:/Users/Właściciel/" sketchup seem not to be finereading the path..
by OnoSendai » Tue Dec 23, 2014 4:19 am
Just tried with a Unicode user name, indeed there are problems with SketchUp 2015, sorry about that, will fix!
by OnoSendai » Wed Dec 24, 2014 2:12 am
This is actually quite tricky to fix due to many bugs in Ruby. (the language used for SketchUp plugins)
Still working on it..
nosek1995
by nosek1995 » Wed Dec 24, 2014 2:49 am
Ok I'll dig into it and see what will happen when I change folder names
Thanks for the help
snorky
by snorky » Sat Dec 27, 2014 9:24 pm
just a test...
why does the scattered tree have wrong texture?
Aflac
by Aflac » Wed Dec 31, 2014 7:32 am
I too am having the problem of scattered objects not having the correct materials. In my case the scattered objects are linked obj files and they are rendering with the 'default' material.
by OnoSendai » Fri Jan 09, 2015 5:41 am
nosek1995 wrote:It's not working. I installed everything, following the instructions. I have SketchUp 2015. Everytime I open it a thing like that pops out:
Help me! Please!
Please try the new build here and see if it helps:
http://www.indigorenderer.com/forum/vie ... 17&t=13417
Cheers!
by OnoSendai » Wed Jan 14, 2015 4:47 am
snorky wrote:just a test...
Snorky: Please try this build:
http://www.indigorenderer.com/forum/vie ... 17&t=13424
and tell me if it fixes this problem.
If it doesn't, please send me the .skp (and any external mesh files etc..)
by OnoSendai » Wed Jan 14, 2015 4:48 am
Aflac wrote:I too am having the problem of scattered objects not having the correct materials. In my case the scattered objects are linked obj files and they are rendering with the 'default' material.
please try
