Hi there,
I seem to be having this conflict between skindigo.rb and additionalpluginfolders.rb when they are both in the default plugins folder, though if I only use one at a time it is fine. When both installed together Sketchup crashes on startup. Is this an issue that can be resolved?
Cheers
Additional Plugin Folders.rb Conflict with skindigo.rb
- richyrich33
Re: Additional Plugin Folders.rb Conflict with skindigo.rb
Hi,richyrich33 wrote:Hi there,
Cheers
I would have to do some testing. I have never used additionalpluginsfolders.rb.
Make sure that if you move SkIndigo.rb, you also move the folder 'skindigo' to the same folder.
- richyrich33
Yeah I use the additional folders plugin to link up to my dropbox account so I can share my plugins across a number of work stations in different offices. I use Indigo on one computer so have left skindigo in the default plugins folder, which causes the conflict with the additional folder plugin.
I tried sticking skindigo and its associated folder in the dropbox folder too, accessing it through the additional folder plugin though this crashed Sketchup on startup too.
Yeah if you have a chance to look at this that'll be great!
Cheers
Cheers
- richyrich33
Hi have you had a chance to test that plugin yet Whaat?
Cheers
Cheers
